Fashion Guru
bore
so what exactly does a boring the engine do? What are the benefits of it and how much would it cost to get it done?
2000 Mustang V6
Boring the engine out consists of taking material off the sides of the cylinder block walls in order to achieve larger displacement by using larger sized pistons. This would equate to more cubic centimeters per cylinder (cc's) and thus more horsepower. You would have to strip the engine down to isolate and remove the cylinder block in order to have it taken to a shop and bored out. As for cost, that depends on how much of the work you do yourself to strip the top end of engine down. Probably looking at several hundred to bore out a stripped cylinder block. Then you would need to buy new pistons, rings, wrist pins, etc. And depending on your horsepower goals you might want to buy stronger rods as well. The whole setup can definately get costly with labor and everything. Might be anywhere between $1k and $2k depending on quality of parts used in the top end rebuild.
This shows machining a block
Boring and honing is not usually done to increase power, though it will increase it slightly. It is normally done to correct worn cylinders. |
2000 Mustang V6
I always wondered how they managed such precision...good video.
Fashion Guru
thanks
¡ʇsnq ɹo uʍop ǝpısdn
im surprised they didn't use one of those stress plates or w.e on the top to apply normal cylinder head pressure to the block... this is said to increase accuracy and life of a block...
boring is also considered a "clean start" for an older used engine... it helps eliminate imperfections in the cylinder walls and what not
Threads Similar to: bore
| bore | Iownastang | 5.0 Mustangs | 11 | February 5th, 2008 11:18 PM |
| head bore? | sniperrider | 5.0 Mustangs | 4 | June 4th, 2007 06:01 PM |
| 302ci bore to 347. | stang94 | 94-95 | 2 | March 21st, 2007 04:41 PM |
| stock bore | Stock | 5.0 Mustangs | 1 | January 7th, 2007 01:56 AM |
| Bore Size | cali 5.0 | Modular Mustangs | 8 | November 1st, 2006 03:00 AM |
