Oil Pressure Question - Page 2
Old May 16th, 2008, 08:29 PM   #21
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
^ a mechanical oil pressure gauge
Old May 16th, 2008, 08:54 PM   #22
Modified88Dreamer's Avatar
1988 Mustang GT
N/A
Modified88Dreamer will become famous soon enough
Originally Posted by 99v6stang View Post
okey i changed the oil and oil filter, and the pressure sensor. Still shows no pressure after i started the car, and now it threw P0453 Fuel Tank Pressure Signal circuit Input above maximum which im assuming has something to due with the svt fuel pump i just put in, what is wrong there? I only ran the car for about 10 seconds but it sounds like it is knocking or something and isnt making good sounds. Yes possibly the cam bearings could have gotten damaged, but i dont know. Would a scratch or something cause this or would it have to be the thing destroyed
When you put the new pump in you could have done damage to FTP sensor. Other possible causes could be that the FTP circuit is open, a damaged PCM which I highly doubt, SIG RTN circuit could be open, VREF (reference voltage) shorted to VPWR, and last the FTP could be shorting to the VREF or VPWR. If you can monitor the FTP V PID reading greater than 4.5 volts with Key On Engine Off it indicates a hard fault. Also would like to add that if and when you monitor the oil pressure from a mechanical one it should read 40-125 psi at 2500 rpm (Hot)
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"!
Old May 17th, 2008, 09:59 AM   #23
stephen has a spectacular aura aboutstephen has a spectacular aura about
the fuel pump was a 310 vmp svt fuel pump so it shouldnt have any problems
I will check about the oil filter. That would have for sure filled up in like ten seconds of running?
Yes.
What kind of a guage do i need to check the oil pressure.
Any kind of after market mechanical gauge will work ( I have a VDO). They connect up by tubing with a compression fitting on the end. You will probably need an adaptor to connect it in place of the oil pressure sender. If you take the oil pressure sender with you they can determine the thread size. For a Mustang the correct adaptor may come with the gauge.
Old May 17th, 2008, 10:32 AM   #24
This is one option for an oil pressure gauge
http://store.summitracing.com/partde...5&autoview=sku
Old May 18th, 2008, 12:12 PM   #25
99v6stang's Avatar
99v6stang is on a distinguished road
so what do you guys think could be causing this problem?
My car ---- (m112 in progress)
Old May 20th, 2008, 01:25 PM   #26
I haven't posted further on this because I assumed you want to get other opinions.
Did you check if the oil filter filled up? If it did the oil pump is working.
It would be useful to measure the oil pressure with a gauge just to be sure, but since your also hearing engine noise, I think you really do have low oil pressure.
Possible causes are excessive clearances in the oil pump, a stuck pressure relief valve, or excessive clearances in the bearings.
Old May 21st, 2008, 12:57 PM   #27
99v6stang's Avatar
ok well i havent figured out anything but im pulling the motor tonight and checking for possibly warn bearings or a bent rod or who knows what. Im hoping to leave the heads on because dont wanna pay $100 for new gaskets.
Threads Similar to: Oil Pressure Question
oil pressure and water temp gauge install question hardhitter 99-04 34 April 13th, 2008 05:44 PM
oil pressure rainier446 99-04 7 March 26th, 2008 10:21 AM
Oil Pressure Question Danedog311 2.3 Mustangs 1 January 15th, 2008 10:56 AM
Oil Pressure Gauge Question Pastor J 2005 - 2010 6 September 6th, 2007 12:25 AM
oil pressure oasr87 V6 Mustangs 4 July 16th, 2007 12:40 PM
