96 Overheating
Old October 30th, 2006, 12:48 AM   #1
Look Ma! My First Post!
6 banger stang is on a distinguished road
96 Overheating
i have a 96 v6 mustang and the temp. gauge in the dash shoots up to hot after about 10 min. of driving. my coolant resevoir tank is also bone dry but has no leaks. it also blows out cold air when i put the heat on. theres no smoke coming from anywhere, exhaust or engine. anyone have any ideas of what could be wrong?? thanks
Old October 30th, 2006, 12:54 AM   #2
¡ʇsnq ɹo uʍop ǝpısdn
yea ... the heater thing... you will wanna check the heater core hose... its right behind the ditributer... and runs to a metal pipe right above the valve cover ... follow that all the way to the firewall...
check your fuses too... and put some coolant in it...
i might be able to help you with the heater hose if its blown ... or split ... i replaced mine.. its a pain
Old October 30th, 2006, 01:58 AM   #3
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
It sounds like you may have a blown head gasket. Check and see if your losing any coolant or if theres any residue collecting on the inside of the radiator. Signs of blown head gasket would be Upper radiator hose is very pressurized after running for more then 10mins but only air is in it, not radiator fluid. Your heat also will not function. it will seem to be a problem with the thermostat not opening, however thats not the case.
If your coolant level has not changed at all and no residue is found then consider replacing the thermostat.
95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit,
GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp
96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap
Threads Similar to: 96 Overheating
OVERHEATING sweetrolls 5.0 Mustangs 4 July 27th, 2007 09:39 PM
overheating engines.. mustang500hp 96-98 0 April 16th, 2007 12:43 AM
Overheating MustangGTNY 5.0 Mustangs 9 November 2nd, 2006 11:40 AM
Overheating! But Why? Unreal V6 Mustangs 1 September 6th, 2006 05:55 PM
Overheating 90Stang 5.0 Mustangs 19 July 31st, 2006 05:30 PM
