dash illumination not working
Ok, so im driving along last night, and my dash cluster lights start flickering on and off and then finally just stayed off. So my dash cluster and the fan/ac controls no longer light up. It doesnt sound like a fuse, because it was flickering for a minute......so i think it would have just died if a fuse blew.I heard that if your ignition is starting to go, that that can cause this to happen also. Anyone ever hear of that....or have any ideas BESIDES check fuses/connections. Id appreciate it if the post whores stay off this thread, and only people with constructive advice try and help. And if someone could post the fuse/wire diagram, that would help too.
01 V6 convertible
too slow to try
can't help ya with a reason why, but I can tell you that all of the wiring diagrams can be found on that library site that HMUSN posted in the General Tech section...
Free Online Manuals hope that helps a bit... and just wondering... is it just the lights on the dash that are out? or are the gauges not working either? |
1998 Mustang V6 5 spd.
With the headlights on, Try wiggling & turning the dimmer control back & forth to see if the rheostat has a bad connection or dirty contacts.
#4 | ||
stupid car
2002 Vert
Warp speed
Hey man I have the exact same problem. I was able to fix mine for a short time by replacing both the fuse under the dash and under the hood. I think they have a short somewhere but not really sure. I cant go and look either for ya cause cars at the body shop getting new bodykit and paint but look in your manual and you should see what fuses they are. Try them and if they blow again then u have a short.
^^^Hey thanks. Do you remember what fuses they were?
Ok, so i was able to fix this problem. Fuse number 37 was blown - the dash illumination one. So i pulled out the dash cluster to figure out what was causing the short. Turns out 2 of the wires had a tiny spot of the outer casing worn off. So once i put electrical tape on the wires, put a new 10A fuse in and it worked perfect.
1988 Mustang GT
N/A
For future reference
Instrument Illumination http://www.motoralldata.com/alldata/...25933/83256656 Instrument Cluster http://www.motoralldata.com/alldata/...26117/83298591
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"! |
i have a haynes manual....got all those diagrams. But thanks
Threads Similar to: dash illumination not working
| Hey Doc and 3.8 dot dot dash dash this! | WAR-PARTY | The Clubhouse | 3 | April 13th, 2008 05:50 PM |
| Speaker Clicking Noise And Dash Lights Not Working | Lastofthe5.0's | 5.0 Mustangs | 5 | April 11th, 2008 01:01 PM |
| I Hate Working!!!!!! | MustangMo | The Clubhouse | 11 | February 28th, 2008 02:14 PM |
| AC not working | chuck&monika | 2005 - 2010 | 5 | August 6th, 2007 01:33 PM |
| Cluster Illumination Color Change | lwhitetrash88l | Visual | 1 | March 26th, 2007 09:08 PM |
