Purge Valve & MAF Replacement Questions
Hello,
I recently threw a check engine light and had Ford look at it on my 94 mustang. It came back with the following: P0443 EMP Vapor Management Valve Fault Ford said the part needed to fix this was the: cx-1324 Which when I did research came up as the Purge Valve (Also, is this just the canistor or what?)... Is this correct? Am I missing something here? And would this be easy for me to do myself? I am low on funds and having a shop do it is expensive. I'm mechanically inclined enough for most things... According to the Chilton book, replacing the EECS stuff seems pretty simple, but I'm not sure. Comments, suggestions, advice, etc would be awesome on this. Also, if anyone has a quick how-to, other than the chilton book. Because this was faulty, they decided to check my MAF as well. They informed me that its starting to go and needs replaced. EDIT: They had said it registered a BADO #145, informing me that it was coming in at 145 hertz instead of what is should be at 159 hertz. Mentioning that it would likely soon cause drivability issues and would throw a check engine light soon. I had intended on doing a Cold Air Intake soon, one of those cheap $80 ones. But now that my MAF needs replaced (with the cheapest I have found new at $170).... I am wondering if I should just do the following instead: www.cnlperformance.com/73mm_V6.html From what I can tell, this would provide me with a fender well cold air intake, and replace my MAF with a newer and better one for cheaper than I could replace the MAF, and buy a different Cold Air Intake. What do you all think? I appreciate your time and help! Thank you. Last edited by RavenSword; May 21st, 2008 at 01:54 PM. |
Threads Similar to: Purge Valve & MAF Replacement Questions
| evap purge valve | adrenaline_junkie_08 | V6 Mustangs | 2 | April 6th, 2010 11:43 AM |
| Evap Canister and Purge Valve | 01sta1k3r | 99-04 | 6 | April 11th, 2008 02:06 PM |
| Purge Valve | RhadCundell | V6 Mustangs | 10 | November 17th, 2007 10:36 AM |
| Purge Valve Questions | Outlaw GT | 99-04 | 15 | February 8th, 2007 03:04 AM |
| Purge Control Solenoid or Purge Control Valve fault | kdevildog01 | General Tech | 3 | July 17th, 2006 01:45 PM |
