what the hell......light still on..new o2
mmmmmmmmk.....a couple weeks ago pulled a code saying my heater was out on my bank one sensor two o2 sensor...so i got the replacement and got under there yesterday and ummm...idk if im blind but i only saw ONE o2 sensor on each side...so i figured since my car is a 94 with OBD2 maybe it was just going by that so i replaced the sensor anyway...but its still throwing the code...how do i replace something thats not there? unless the exhaust shop cut my shit out when i had them put my Xpipe on and cut my two back cats...the only ones i have are right off my manifolds and thats it...but if they did cut em why would it only show the drivers side and why call it just a heat malfunction....the car runs fine and gas mileage normal so is it just throwin a bullshit code that cost me 60 bucks haha thanks guys
![]() 94v6.CAI,Exhaust,3:73s-needs rear end rebuild 02GT/Saleen.built motor,62mm turbo 412hp/446tq @10psi,stock TB and intake |
2003 v6
340/373 - yay for belts
i think my car is throwing the same code, well it was(doesn't have an engine in it atm). This was after i put the long tubes on though. didn't really care to fix it though because ^
MM's Resident Ricer
2006 Scion tC
13.001@113
you should have 2 on each side and bank one sensor 2 would be passenger side rear sensor so make sure you replaced the right one
i only have 2....period....and i was told multiple times it was drivers side downstream..wtf...
so should i take the old one i pulled out and put it in the passengers side and reset my system? this is pissin me off ha i wanna know why i only have two sensors as well...unless im just blind as hell and didnt look up but i only have 2 cats left and these sensors are BEFORE the cats so...
MM's Resident Ricer
2006 Scion tC
13.001@113
yeah do passenger side. Bank one on a ford is passenger side
after you replace the sensors, rest the code and disconnect the negative on the battery. The code may just be stuck in the computers memory.
yea i reset it when i did the drivers side...summa bitch....so should i take the old one from the drivers side and put it in the passengers or should i put the new in the passengers that i put in the drivers or does it make a difference..i know i should do both new at once but im broke...
if your still throwing a code you need to erase it
if it continues and you dont have cats then your cat is reading you dont have the sensor plugged in...throwing a code because the cat is gone and so is the sensor
96 Nissan D21
Low and stupid.
This happened to me and I ended up replacing the same sensor three times (autozone paid for two of the sensors because they thought they were faulty) and then I got sick of it and got a diagnostics check run on it and the handheld code reader was wrong and it was a completely different sensor. May wanna try that before you replace uneccessary stuff
#11 | |
MM's Resident Ricer
2006 Scion tC
13.001@113
put on the new one on the passenger side and clear see if that works
replaced both sensors...light is still on..weak sauce...im guessing its throwing the codes because the sensors arent actually there...but why is it only the code on the passengers side and not the drivers side..and why is just the heater and not the actual 02 and i have apparently been missing them for about 2 years now ha
1995 Mustang convertible
They must have cut 2 of your O2 sensors. The downstream sensor should be located after your cats. And on the stock 6 would be in the y-pipe. So I'm betting that's the problem. BTW it is VERY VERY unusual for a 94 to have OBD2. Did you do an engine swap? If you're not having any problems other than the light, I would just go ahead and clear the code.
MWWarlord 1995 Mustang convertible check out my garage for pics and a complete list of mods. http://www.tricktuners.com |
it had a swap right before i got it..so apparently they went ahead and swapped the harness and shit....i wanna know why this code is just now popping up and why its not saying both sensors are fucked...i cleared the code but it came back...now im pissed that they cut my sensors...how unprofessional hahah i just drove to dallas so i could "gauge my miles" and its still the same before the code popped up...so now its just the fact the light annoys me
next time i crawl under there imma search for the cut wires haha
Threads Similar to: what the hell......light still on..new o2
| map light/dome light bulbs | 00gtv8 | Audio/Video | 4 | May 4th, 2008 10:30 PM |
| Head Light and Tail Light Opinion Needed | Laser | Visual | 8 | January 2nd, 2008 02:16 AM |
| Were the hell is everyone | Drick | The Clubhouse | 37 | September 22nd, 2007 01:58 AM |
| light bulb in dome light | myeleanor | 2005 - 2010 | 7 | August 31st, 2007 03:34 PM |
| How you can change your dome light color. (light on roof) | SonicStang | Visual | 25 | March 23rd, 2007 12:39 PM |
