Discussing Tire Size Measurements in the V6 Mustangs Forum. could someone explain exactly what the numbers represent? im confused how you could put a ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Tire Size Measurements |
Example: 185/60R14 85H
The first number is the width of the tire in millimeters, measured from sidewall to sidewall. To convert to inches, divide by 25.4 In the example above, the width is 185mm or 7.28". The second number is the aspect ratio. This is a ratio of sidewall height to width. In the example above, the tire is 7.28" wide, multiply that by the aspect ratio to find the height of one sidewall. In this case, 185x0.60=111mm or 7.28"x0.60=4.36". The last number is the diameter of the wheel in inches. Taken from: http://www.tirerack.com/tires/tirete...e.jsp?techid=7 |
Threads Similar to: Tire Size Measurements
| tire size | wadepetersen | V6 Mustangs | 4 | August 28th, 2007 01:46 PM |
| tire size | dark-samurai2 | V6 Mustangs | 24 | August 17th, 2007 12:02 AM |
| tire size | hopper | 5.0 Mustangs | 4 | June 20th, 2007 11:51 AM |
| tire size. | CobraStang161 | 99-04 | 21 | January 8th, 2007 04:54 PM |
| Tire Size | ermister | V6 Mustangs | 1 | October 25th, 2006 12:33 AM |
