Quick Help (Clicking Noise)
k so motor started making a clicking noise from the upper manifold
. loud enough to hear in the car and speeds up with the tac. what did i do any guesses? It's an 04 with 26 000km so yeah...
1999 Ford Mustang V6
14.79 @ 92.15
upper intake manifold or top of exhaust manifold? usually clicking noises are tied to exhaust leaks
would you say it is more of a tapping or is it like a chirping noise? does it matter if the car is warmed up or cold? any loss of power?
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
k so it;s the upper intake manifold and it's a tapping i got some sound clips if you wanna hear it. so might be a bigger problem then i thought . oil is leaking out but i'm not sure where cause it;s sprayed everywhere. i'm gona hose it down 2morrow and try looking.
i did check for the noise under the car as well for a spun bearing but i'm not sure me and my dad are fightin about which is louder under the car or on top but the sound is definately louder on the drivers side of the manifold.
k so i'm praying it's not a spun bearing or my headers but so far this is what i've looked up. and being a newer car i don't think it's the push rods.
Engine makes a ticking noise: As soon as you start the engine, you hear a ticking noise. It sounds like a pencil tapping. The speed of the noise increases with an increase in engine speed. Possible causes: The valves need to be adjusted: Adjust valves. There is sludge in the engine which is restricting oil flow: Flush engine, replace oil filter and fill with new oil. Hydraulic valve lifters bad: Replace valve lifters. One or more of the engine's valves are stuck: Check valves and repair. (Generally not a DIY job) Push rods bent or worn out: Replace push rods. |
also my OBII codes say it's an oil pressure switch failure
¡ʇsnq ɹo uʍop ǝpısdn
ouch dude that sucks
some of those make sense and some are out of place... on your list ima take a stab in the dark and say that its your valves... that could also be why their is oil leaking too... but thats just my opinion... im no mechanic
yeah i'll let you guys know once i get the other car insured lol cause no one is sure since we don't know where the oil is leaking from.
ok well changed the oil and all that fun stuff. so far no leaks and thank god i did it yesterday cause we had a snow blizzard today lol an di tend to work outside haha. anyways i'm thinking it was clicking cause the oil leaked out and it didn;t have any and now i'm just looking at a bent valve or one that is miss aligned now. but i'll keep an eye out make sure it's not leaking still.
Threads Similar to: Quick Help (Clicking Noise)
| Getting a clicking noise when i get on the gas | Fox2102 | V6 Mustangs | 33 | October 22nd, 2007 12:18 AM |
| clicking noise from engine when starting HELP!!! | victorye3 | V6 Mustangs | 7 | September 3rd, 2007 11:42 PM |
| Clicking .. Tapping Noise ... | BlackStang | V6 Mustangs | 30 | April 2nd, 2007 05:05 PM |
| rubbing and clicking noise | Warlord | Modular Mustangs | 2 | January 7th, 2007 01:47 PM |
| Clicking noise 01 cobra | WVSNS& | 99-04 | 5 | May 10th, 2006 08:35 PM |
