Power Steering Fluid
Old October 31st, 2006, 11:57 PM   #1
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
i really need to change my power steering fluid...its brown, and look like mud...any ideas on how to get the fluid out? with the exception of sucking it out with a hose?
[SIGPIC][/SIGPIC]
Acmillr loves me
Old November 1st, 2006, 07:34 AM   #2
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
you have to siphon it out by mouth....lol
you should be able to remove the drainback hose then fill it back up.... to bleed it you will need to turn the pulley by hand to pump the fluid, if you can't turn the pulley, you can remove your coil wire so your car won't get spark then turn it over once fill the fluid, do a couple of more times but don't let it run dry until the bubbles are gone. then hook the return hose back up and with the front end still up in the air, turn the rack manually (steering wheel) without turning the car on about 20 times from full left/right to get the bubbles out. then start the car and turn the wheels about another 20 times and refill the fluid if needed. check for leaks or whining noises from the pump.
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Threads Similar to: Power Steering Fluid
power steering fluid the68stangdude Classic Mustangs 1 August 20th, 2007 06:02 PM
Power steering dr.gonzo! 5.0 Mustangs 3 May 19th, 2007 06:35 AM
Decreasing power steering pump pressure for tighter steering 83 5.0 5.0 Mustangs 6 January 7th, 2007 08:24 PM
power steering terribleonexx88 5.0 Mustangs 4 December 27th, 2006 07:50 PM
Power Steering?? RedHott66 V6 Mustangs 2 December 22nd, 2006 06:17 PM
