2002 Mustang
*Help*Amp wiring in a vert stang
Hey everyone got me a new stang well a 04 but still.Its a vert and i was wanting to install a new amp and subs but unlike a regular stang the back seats dont let down.How would i run the wires from the cabin to the trunk??
Admanistrator
do most stangs have back seats that go down? my '06 vert doesnt either...
but sorry cant help. maybe run it along the undercaraige |
MM's Resident Ricer
2006 Scion tC
13.001@113
umm they should go down
Ya...they go down.
1995 Mustang convertible
I can't say as far as the 04...but the 95 vert rear seats DO NOT GO DOWN. The motor to put the top down is located right behind the rear seat. However, you can remove the seats. You could remove the seats run the wires then replace the seats. You might have to drill a hole to get to your trunk though.
MWWarlord 1995 Mustang convertible check out my garage for pics and a complete list of mods. http://www.tricktuners.com |
2002 Mustang
Verts dont have seats that let down bc sumhow the convertible top is connected to the back seat rest.does anyone kno how the pop out?
2000 Mustang V6 Vert
Verts DO NOT have seats that go down, you have to take them out. If you pull up on the bottom seat cushion, there is a little clip holding the cushion in place around the middle of where a person would sit, one on the driver's side and one on the passengers side. Take a flat head screwdriver and push on the little 'button' part, mine took a fair amount of force, and pull up on the seat cushion with a little bit of force. Repeat on the other side. The bottom seat cushion will now just lift out, then there will be two bolts that are now visible holding the seat back in place, undo them and the back will lift out. Now you can see a small gap that will lead in to the back of the trunk. If you can't find it put a flashlight in your trunk and look for the light shining through.
I ran the pwer wire through the rest of the car, starting from the battery, pass ingthe power cable through the fuse (in the first 12 or 18 inches of wire from the battery), then through the rubber grommet on the drivers side of the firewall, under the carpet by the door, under the rear seat and in to the trunk. To run it under the carpet you just pull up on the door sill piece of plastic (it is just clipped in), and then unbolt the seatbelt from where it attaches by the carpet, and just lift the carpet up. I think I also removed the interior panel where the hood popper is. Running the wires from the deck are very similar to the power wire. Just make sure you run your signal wires on the opposite side of the car as your power and remote amp turn on wires. |
Threads Similar to: *Help*Amp wiring in a vert stang
| Wiring subs/amp | d2daj86 | Audio/Video | 4 | August 19th, 2007 09:07 AM |
| B&M Hammer Shifter in 01 Stang | jrfan4life | 99-04 | 18 | August 12th, 2007 12:56 AM |
| Reccomended wiring from amp | exofreeze | Audio/Video | 3 | July 23rd, 2007 06:35 PM |
| q&a for my new 2000 stang | Sam'sWildStang | V6 Mustangs | 13 | February 18th, 2007 09:57 PM |
| Sub/Amp Wiring? | Xeremeh | Audio/Video | 0 | December 10th, 2006 03:11 PM |
