#21 |
ok ill recheck all the hoses and see if i can find any loose hoses
The LS1 was finally subjected to a paternity test, and it's daddy was to '03 Cobra |
#22 |
ok...i checked all the hoses and i shorted the iac...and i made sure that i didnt have a vacuum leak....but it still will not start up...but when i have someone hold the throttle body it will start up but it will backfire alot...and it smells a little like fireworks...i am stumped on this one...any comments is welcome
#23 |
MM's official Chevy guy
check you plug wire order case i had a smiler problem when i put my new wires on and fucked up the order
![]() "Speak softly and carry a big stick" - Theodore Roosevelt "Any idiot can make a V8 fast, it takes a real idiot to make a fast V6". ![]() '02 Mustang N/A 4.3 stroker away for winter '72 Chevelle project car 454 coming '93 Bronco EFI 351W DD |
#24 |
+1 on that dude...super easy to do when you think you got it right...then boom.
![]() 94v6.CAI,Exhaust,3:73s-needs rear end rebuild 02GT/Saleen.built motor,62mm turbo 412hp/446tq @10psi,stock TB and intake |
#25 |
MM's Database Error
did you ever figure this out?
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
#26 |
um....i will check the wires but i doubt that its that...because i checked them before...but like yall said its easily over looked..
#27 |
ok...i have checked everything that there is to check...i checked plug wires vacuum hoses any type of air leak (i even put silicon around the ports on the intake) i shortened the iac all wires are are connected except for 2 which go to the egr which i deleted i changed the computer because my ecu was modified with 3 degrees advanced timing....and now it wont even try to crank up...before it cranked up but it was really really ruff and it didnt want to stay cracked unless you held the throttle body...
#28 |
what happens when you turn the key?
#29 |
it just spins...it doent try to start or anything...
#30 |
but the car turns over?
hows the fuel pressure looking also how fast does it crank make sure the battery is charged as well, if its been sitting it will die slowly
#31 | |
no, it does not turn over...it seems that it tries to crank @ normal speed... I can put a charger on it again.
#32 |
MM's Database Error
run recon and see if anything is out of ordinary such as the fuel pressure like torres said
#33 |
The soul stealing Ginger
Whats is run recon mean??
#34 |
MM's Database Error
sniper tuning program....
recon = data logging program
Threads Similar to: windstar intake
| windstar intake | 04mustang232 | V6 Mustangs | 54 | January 29th, 2009 06:07 PM |
| windstar intake | mannymustang | V6 Mustangs | 9 | April 29th, 2008 02:29 AM |
| Windstar intake gains? | Orangester | V6 Mustangs | 33 | August 28th, 2007 10:20 PM |
| Windstar Intake | 2000Mustang | V6 Mustangs | 18 | August 4th, 2007 10:41 PM |
| Windstar intake? | Orangester | V6 Mustangs | 1 | March 29th, 2007 11:07 PM |
