windstar intake
ok...i installed my windstar intake...and it is not cranking up and staying cranked up with out the throttle body being held down...my dad is saying it might be a timing issue...now im starting to think its a timing issue...all vacuum lines are hooked up correctly and there are no leaks (that i know of...and i checked and double checked) and the manifold is torqued to spec...the only thing that is not hooked up is the throttle cable...and i am stumped???
The LS1 was finally subjected to a paternity test, and it's daddy was to '03 Cobra |
hmm idk what to tell you lol, i dont have any windstar intake experiences.. But that cai is kinda akward but cool at the same time
![]() JAKE'S PIITB CREW MEMBER#4 |
hahaha...thats the only way i could get it to work...with out spending too much money
MM's official Chevy guy
what is you iac set up cause i you that can cause cranking issues
and ya definetaly do something about that piping set up, it is horrendous, lots of bends + dryer hose = no good
![]() "Speak softly and carry a big stick" - Theodore Roosevelt "Any idiot can make a V8 fast, it takes a real idiot to make a fast V6". ![]() '02 Mustang N/A 4.3 stroker away for winter '72 Chevelle project car 454 coming '93 Bronco EFI 351W DD |
that was my main concern was with the iac...and i took it out and resealed it and made sure that there were no leaks in it...and i double made sure that the hoses were going into the right spot...and with the intake...thats what i could do witht the money i have right now...and its not staying like that believe me...ill change it when i get the money
is that your iac all the way by the fire wall
because that might be the problem, it being so far away so see if you can shorten it up and see if that helps
ya thats my iac...i could put it up closer to the tb...i can do that saturday because i work tomarrow and friday...ill let yall know what happens....so you dont think its a timing problem???
i think it is just the iac being so far a way, because i have heard that causing the same problem you are having
also looking at the pics again it doesn't look like your maf is plugged in, and if that is the case it might be contributing to your problems
#9 | |
MM's Database Error
damn i didnt even think about the iac being far away, i do remember people talkin about that causing cold crank problems. yea is ur maf plugged in??
MM's Database Error
how many things did u run to the other side...i kno theres the pcv and then theres 2 lines that came from the old intake
looks like you MAF was unplugged
make sure you MAF and hoses go to the correct hole if its the opposite way it wont start do you here a loud whistle while its on? hold the throttle are a certain rpm so it stays on and spray carb cleaner to check for vacuum leaks
¡ʇsnq ɹo uʍop ǝpısdn
I would also like to remind you to check the Mass Air Flow sensor... oh and, you don't need to route your intake piping the same way as it was, be creative and come up with something different if you want
#13 | |
MM's Database Error
![]() iTrader: 2 reviews
can someone please point out the iac? what does it stand for and what does it do? thanks dont mean to bash your thread but im confused
ya my maf is plugged up...it just looks unplugged in the pic...and the hoses go to the correct place...and yes i do hear a whistle while its on
you've got a vacuum leak somewhere then
Its your Idle Air Control...it does pretty much what its called..its there to help regulate the amount of air coming in so your A/F ratio will be correct and your car will run properly..
![]() 94v6.CAI,Exhaust,3:73s-needs rear end rebuild 02GT/Saleen.built motor,62mm turbo 412hp/446tq @10psi,stock TB and intake |
boosted v6
11.90@114
ok iac need to be shorted up alot ,check your tps wires you used the same color could you have switched one or two of them ? also check you coil pack are the wires in the rite spots.did you unplug anything else cps maybe ?sorry if i sound like i doubting your work but trying to cover the basics
#19 | |
go back and check all the little things, because it is the little things that are so simple that you don't think you can screw up that bite you in that ass cause you screwed them up and don't check them till you have triple checked every thing else
#20 | |
Threads Similar to: windstar intake
| windstar intake | 04mustang232 | V6 Mustangs | 54 | January 29th, 2009 07:07 PM |
| windstar intake | mannymustang | V6 Mustangs | 9 | April 29th, 2008 03:29 AM |
| Windstar intake gains? | Orangester | V6 Mustangs | 33 | August 28th, 2007 11:20 PM |
| Windstar Intake | 2000Mustang | V6 Mustangs | 18 | August 4th, 2007 11:41 PM |
| Windstar intake? | Orangester | V6 Mustangs | 1 | March 30th, 2007 12:07 AM |
