Guesses on rwhp/rwtq please
I have a 2002 auto v6. I am looking to get the following mods done. What do you guys think ill see on the dyno?
BBK shorty headers Custom off-road x-pipe Flowmaster dual exhaust SCT Livewire K&N drop-in filter Air silencer removed Ported Heads with 1.900 intake and 1.570 exhaust valves Compcams billet cam: 212/218 duration,110lsa,.540 lift Ported upper/lower intakes Comp adjustable roller rockers ASP 25% underdrive crank pulley Ford Racing 4.10 gears Ford Racing posi-trac differential |
with a tune 220rwhp+
Fashion Guru
why dont you get a CAI?
2004 Mustang V6
good luck getting some 4.10s by ford racing. i tried every where. they are discontinued. just get some motives they work fine.
2004 Mustang 3.9L V6 with K&N intake, Dual Flowmaster Super 40s, Motoblue 42% Pulley, GT rear sway bar, drilled and slotted rotors, SCT tuner, Black FR500's 17 by 10.5 and 17 by 9, 4.10 motive gears and FRPP T-Lock. |
#5 | |
2002 Ford Focus
slow as fuck
![]() iTrader: 4 reviews
![]() if you get 25% underdrive pullies, longtubes instead of shorties, aluminum driveshaft, bigger cam, an ebay cai, 65/70mm throttle body, and intake spacer, you could see another 20-25rwhp out of that setup
99 V6 Mustang-sold 02 Ford Focus-sold 98 Camaro Z/28-lid, catback |
That's about what I would say as a safe estimate, but I wouldn't be too surprised to see it significantly higher, either.
I say that because my car makes ~220whp with stock valves, stock headers, stock crank pulley, stock rockers, take-off exhaust, and stock intake manifolds.
1993 2.3L Coupe [Motortopia] : Open-Track Project... 216k miles 2000 V6 (Black,5-speed) [Motortopia] : Heads/Cam (EXHAUST CLIP) 2001 Harley Davidson F-150 Acts 16:31 |
#7 | |
i like to say that estimate mainly because thats what others have seen aboutbut then you have low compression motor with similar top end making the same... stock compression stock motor 220+rwhp is safe to say with porting you tend to see more power then torque. the car will have a good top end which these cars lack stock
#8 | |
im already getting a pulley and a 65mm throttle body. and an intake spacer.
muneris pro ego
no need for the intake spacer... waste of money
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
2002 Ford Focus
slow as fuck
your thinkin threottle body spacer, the intake spacer actually makes power. it makes about 5rwhp and 7rwtq at low rpm and about 2rwhp and 3rwtq at higher rpm. its more of a low end power mod but it does work and for just $120 its def worth the money
2000 Mustang V6
so with all these mods done would he be beating stock gts?
no shot at the 05+ gt's but i believe i can beat or at least keep up with the 99-04 stock gt's on the quarter mile. especially if its an auto. but if not, a pi 3200 stall should do the trick. hp wise, ill be right with them, but the torque is what bites me in the ass. with the gears and torque converter, im hoping to have my torque multiplied enough to make up the difference.
and i just dont know about that 220rwhp mark. whether i have a pulley or not or a full exhaust or not, everyone keeps telling me that ill have 220. ill be having all the bolt-ons minus the cai and longtubes. i dont see why 230rwhp isnt possible. but anyway for next summer, i am planning on some forced induction. im told that the vortech basic kit outperforms the procharger basic kit. is this true? and with an 11psi setup and everything mentioned on this page could i beat a stock 03/04 cobra? i know they have about 380hp and dont lose much at all to the wheels, but i also know that they arent setup for the track.
muneris pro ego
if you get a supercharger then take off your UDP when you get ready to blow it
and 220 is a good estimate. they also said 220 or above, so you should see 220 at the least
#16 | |
dyno tune from justin worth nothing ![]() i think not
1998 mustang 3.8l v6
whats the dif between a throttle body spacer and intake spacer
? can i have a link to an intake spacer.
![]() RACING because baseball,basketball, bowling,football, and golf only require one ball |
throttle body spacer goes between the cai and the upper intake manifold. they dont do anything. the intake spacer goes between the upper and lower intake manifold. it lenghtens the runners to make more power down low. and it also keeps the upper intake manifold cooler so that the incoming air stays cooler as well.
2000 Mustang V6
yeah i mean 05 under gts...and i dont see how you cant beat them with those mods seein as stock gts have 260 crank hp and about 221 rwhp so it should be a good run with em
you could see 230..my guess is 220-235rwhp
Threads Similar to: Guesses on rwhp/rwtq please
| some rwhp guesses please? | tigerfan2771 | V6 Mustangs | 36 | April 17th, 2008 08:34 PM |
| RWHP and 1/4? | suprajay79 | 99-04 | 26 | February 29th, 2008 04:13 AM |
| track time guesses | nes | 96-98 | 2 | October 22nd, 2007 12:12 PM |
| how much horsepower?any guesses? | maddymac07 | 99-04 | 24 | June 20th, 2007 07:48 PM |
| Race guesses? | Stang6899 | V6 Mustangs | 19 | January 12th, 2007 01:02 AM |
