LinkBack (1) | Thread Tools |
#81
MM's Database Error
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
#82 |
#83 |
MM's Database Error
its fords new hand crank v6
#84 |
muneris pro ego
i didnt know they cam out with those already!!! maybe chris got the prototype
Buy my M90 Kit and my Gears and T-Loc! MM ZDC - Alaska Base Commander MM+ Cleavage Club #24 MM Cares Crew / Military Crew M2C2 President / USCG - OS2 ![]() |
#85 |
2004 Mustang V6 Vert.
328/419 @ 4000 rpms
damn .. good job at breaking it
now get it fixed!
#86 |
ouch!!!!
#87 |
thanx for the vid and pics chris there very helpful
#88 |
wowee
![]() 94v6.CAI,Exhaust,3:73s-needs rear end rebuild 02GT/Saleen.built motor,62mm turbo 412hp/446tq @10psi,stock TB and intake |
#89 |
So it looks like all the damage was in #1 cylinder. It shows damage to the piston and valve and the hole in the oil pan is below it, plus #1 piston doesn't move.
You might be lucky enough to just need a new piston/rod assembly and a few new valves, plus possibly a new or reground crankshaft. Between the two engines you have you should be able to build one good one and have parts left over. |
#90 |
Also a new crankshaft from Ford is ~$270 and a new rod is ~$80 if you want to go that route.
#91 |
its not worth it though
i can get a 4.2L crank for nearly half that price. and a rod for $50 i'd need about $100 in bearings $80 oil pan none includes shipping then i need, timing cover gasket, front crank seal, clean the block, which then new cam and balance shaft bearings also you cant see my camshaft but the wear is pretty nasty on it. obdnanrs motor is in awsome shape looks new with oil in it his camshaft is in awsome condition as well my 00 block i will use for future 4.2/4.3L build i see where your coming fromt but its much easier to just use obdnanrs motor his timing cover is still on. nothing is broken. just going to clean his oil pan and paint it. install that and clean off his cylinders. then clean the surface where the head meets and just wait till i've got my set of heads om working on done. Im considering a light regrind camshaft w/longer push rods and shims
[SIGPIC][/SIGPIC] Acmillr loves me Last edited by itschristorres8; June 6th, 2008 at 01:44 PM. |
#93 |
[8MINUS2]
Chris what year is obnar's motor?
Swapping your lower to his if your car has IMRC"s I hope....
#94 | |
lol no thanks, im doing modifactions to it so if fits nicely in the light spot
I'm not even using the heads on his car his motor is an 01
#95 |
2003 v6
340/373 - yay for belts
my new one is an 01 my old is a 03, well i guess its chris's now lol
#96 |
1995 Mustang convertible
Wow dude that really sucks. Good luck. I hope that you're not out of commission for too long. BTW how are you getting around without the stang?
MWWarlord 1995 Mustang convertible check out my garage for pics and a complete list of mods. http://www.tricktuners.com |
#97 |
It makes sense to put a used short block in for now to get it running again and later build your current motor to a 4.2. If you are planning to drag race the car you really should have more than one engine anyway, since things are likely to break.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/73528-so-finally-blew.html
| YouTube - my blown V6 turbo motor | This thread | Refback | June 20th, 2008 06:29 AM | |
Threads Similar to: So it finally blew
| Well She Blew Up | MustangMatt96GT | The Clubhouse | 291 | May 12th, 2008 04:22 PM |
| I blew the motor | cams-shelbycobra07 | 5.0 Mustangs | 125 | May 6th, 2008 02:25 PM |
| so i blew my motor | 98gt760 | 96-98 | 53 | January 30th, 2008 11:35 PM |
| I think I blew out!!!! | Top Gear | Audio/Video | 21 | September 26th, 2007 03:47 PM |
| Blew Something | JRubin2000 | 99-04 | 11 | November 2nd, 2006 07:01 PM |
