Replacement of fuel pump?
LinkBack (1) Thread Tools
Old May 30th, 2008, 11:14 PM   1 links from elsewhere to this Post. Click to view. #1
mustangsusie is on a distinguished road
Thumbs down
O.K. I have a 2000 v-6. I need to replace the fuel pump. I know the tank needs droped.I am new to mechanics.Help!!!! I need step by step directions. Thanks Everyone......
Old May 30th, 2008, 11:20 PM   #2
Modified88Dreamer's Avatar
1988 Mustang GT
N/A
Modified88Dreamer will become famous soon enough
  1. Disconnect the battery.
  2. Relieve the fuel system pressure.
  3. Drain the fuel tank. (Unless its 1/4 full or less you wont have to)
  4. Raise vehicle
  5. Remove the filler pipe bolt attachment and disconnect the filler pipe hose connections to the fuel tank.
  6. Disconnect the fuel tank electrical connector.
  7. Disconnect the vapor tube fitting at the left front of the fuel tank.
  8. Disconnect the EVAP canister tube and hose.
  9. Place a safety support under the fuel tank.
  10. Remove the front two bolts from the fuel tank support straps and swing the LH strap out of the way.
  11. Remove the RH fuel tank support strap bolt and remove the strap.
  12. Partially lower the fuel tank and disconnect the fuel line.
  13. Cut outer edge of pipe-to-tank grommet to facilitate pipe removal and carefully remove the grommet from the fuel tank. Take care to avoid damage to the filler pipe check valve. CAUTION: The filler pipe grommet must be removed prior to removing the fuel tank from the filler pipe or damage to the fill tube check valve will occur.
  14. Lower and remove the fuel tank.
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"!
Old May 31st, 2008, 01:36 AM   #3
juan310's Avatar
juan310 is on a distinguished road
Send a message via AIM to juan310
BAT Auto Technical-Professional mechanics giving advice-An Educational Site w/ OBD2 Trouble Codes and Technical info & Tool Store.
wait till the low fuel comes on. and also buy a new filler pipe gasket from ford only 20 bucks. before you slide out the tank tear/cut the old gasket. put the new one on before you slide in the filler pipe with some lithium grease. youll need the fuel line disconnect tool.
Pioneer Sound System (Comp Speakers-Amp-Deck) - Viper Alarm/Remote Starter
Eibach Pro Kit - Smoked CC Headlights - 18" Bullitt Wheels - SVT Focus Fuel Pump
True Dual Exhaust - Flowmaster Original 40s - 3.5 Rolled/Slanted Tips
Old May 31st, 2008, 09:10 AM   #4
2004 Mustang V6 Vert.
328/419 @ 4000 rpms
plove71387 is on a distinguished road
haynes manuals are at pretty much any car store, you should pick one up there like 20-25 dollars and help you do EVERYthing with your car for repairs.
Old May 31st, 2008, 08:04 PM   #5
Fashion Guru
gooberhead320's Avatar
gooberhead320 has a spectacular aura aboutgooberhead320 has a spectacular aura aboutgooberhead320 has a spectacular aura about
this is perfect timing because i was gonna ask how to install my new SVT Focus fuel pump
Originally Posted by 93hatch View Post
goobers car would whoop on ur fox so you sir fail
im so gay i wish my gf was as pretty as goober
I love 93hatch
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/73616-replacement-fuel-pump.html
MySpace.com - External Link Alert This thread Refback October 19th, 2009 12:36 AM
Threads Similar to: Replacement of fuel pump?
Need real answers for 98 GT fuel pump replacement Hotrodvdog 96-98 8 May 17th, 2011 08:11 PM
Fuel pump question. Stock GT pump to GT (supercar) pump. Nate's4.6 99-04 15 May 14th, 2008 02:25 PM
Suggestions on Fuel Cell's & Fuel Pump bstang 2.3 Mustangs 5 January 21st, 2008 09:04 AM
Water Pump Replacement Snipe061 V6 Mustangs 3 June 1st, 2007 05:11 PM
Fuel Tank Replacement oltimer 94-95 9 January 24th, 2007 07:40 PM
