A few questions...
Old June 1st, 2008, 07:02 PM   #1
2000 Mustang
AMR91 is on a distinguished road
Send a message via AIM to AMR91
A few questions...
Hello, I am new to this forum and I own a completely stock 2000 v6 automatic Mustang.
I am thinking about doing a few upgrades but I have a few questions first.
First question- Is this a good CAI for the price because I don't have too many upgrades and I don't want to spent to much on a CAI if I don't need it that bad. (Cant post links yet but it is the one from Americanmuscle for $75).
Second question- UDP's...I have read a lot about these but has anybody had any negative effects from them such as dimmer headlights or something...Just wondering. And also if I were to buy a set of UDP's would I buy a set that comes with three pulleys? I heard FRPP is the best but would any brand work the same? And would I need to buy a new belt for the new pulleys?
Third question- Gears...I have also read a lot about the 4.10 gears which I am leaning more towards buying than the 3.73 gears. I have heard but I am not sure if it is true, but are the 4.10 gears harder on your engine? I don't do too much highway driving that far, but a few times during the winter season I may drive a few hours on the highway to go snowboarding. So I was wondering if these were the right gears for me?
Also, I know I have to buy a tuner if I were to buy new gears. Which tuner do you guys recommend, and it is easy enough to use so I could tune it myself (btw I am kind of new to this if you haven't guessed already, so keep that in mind). And what else do I need to buy with the gears to get everything working and running well.
WHEWW...sorry I asked so many things, hopefully you guys can answer most of them for me.
Old June 1st, 2008, 08:17 PM   #2
2004 Mustang V6
04DSGV6 is on a distinguished road
Welcome to the forums. My answers are in red. For future reference please use the search button.
First question- Is this a good CAI for the price because I don't have too many upgrades and I don't want to spent to much on a CAI if I don't need it that bad. (Cant post links yet but it is the one from Americanmuscle for $75). Yes, buying a cheap one is just as good as a KN or any name brand
Second question- UDP's...I have read a lot about these but has anybody had any negative effects from them such as dimmer headlights or something...Just wondering. And also if I were to buy a set of UDP's would I buy a set that comes with three pulleys? I heard FRPP is the best but would any brand work the same? And would I need to buy a new belt for the new pulleys? Only electrical problem you will have is if you are running amps for subs or something. 3 pulleys will free up more hp. I believe MOTO blue pulleys are the only ones people say to stay away from because they warp. You will need a new belt
All that the gears will do is raise your RPMs a bit and lose some MPG like 1-5. Not hard on the engine really. If you have an auto go 4.10 if manual do 3.73
Also, I know I have to buy a tuner if I were to buy new gears. Which tuner do you guys recommend, and it is easy enough to use so I could tune it myself (btw I am kind of new to this if you haven't guessed already, so keep that in mind). If you are new to this I wouldn't tune it myself further than adjusting for the gears. If you really want to tune it yourself diablo tuner is the way to go. Most people here prefer SCT and Trick Tuners will sell you an SCT tuner with two years of free tunes. If you have big plans for the car that will need a DYNO tune use whatever the Dyno shop uses.
And what else do I need to buy with the gears to get everything working and running well. I would throw in a T-Lock. While you are upgrading gears why not add in one. V6's aren't equipped with them from factory just GTs. You will need a master bearing kit and new fluid + friction modifier. Don't try to installl yourself, get a few quotes from shops.
Old June 1st, 2008, 08:32 PM   #3
2000 Mustang
Thank you for clearing up some of my questions...BTW I did search this stuff before I asked. I just needed a few specific questions answered.
Old June 1st, 2008, 08:34 PM   #4
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
welcome to the forums man.
Old June 1st, 2008, 08:40 PM   #5
mooses is on a distinguished road
I have a 25% UDP and if I'm sitting at idle with my lights and wipers on, the lights will be just a tad dimmer than normal. If you are driving with rpms any higher than idle, this won't be a problem unless you are running a large sound system.
You will love 4.10s if you decide to go down that route. When I had my auto + 4.10s, it definitely woke the car up more than all the mods I had done combined. You might notice a slight loss in mpg for city driving, but you will definitely lose mpg on pure highway trips. I lost around 4-5 mpg highway.
Old June 1st, 2008, 09:36 PM   #6
2000 Mustang
thanks for the help..That is kind of a lot of mpg loss for those new gears. I didn't know you would lose that much.. And for the UDP's it doesn't so dim its hard to see right? And are there any other negative effects from them.
Old June 1st, 2008, 09:56 PM   #7
No, it doesn't dim that much. It's just enough where you can notice the difference if you blip the throttle. You wouldn't notice it if you aren't looking for the change.
Old June 1st, 2008, 10:07 PM   #8
2000 Mustang
ok thanks
Old June 1st, 2008, 11:37 PM   #9
2000 Mustang
Does a 2000 v6 Mustang have a 7.5 rear end, not and 8.8 right?
If so will these work? eBay Motors: Ford Mustang Racing 4.10 7.5" Gear Set V6 3.8 (item 280230742602 end time Jun-02-08 20:43:30 PDT)
Old June 2nd, 2008, 12:01 AM   #10
2004 Mustang V6
yes to both
Originally Posted by 06RedfireGT View Post
The idea of smashing your face on it in an accident isn't so sexy.
Old June 2nd, 2008, 12:58 AM   #11
2000 Mustang
Alright. Do you think those gears are good or should I be looking at other gears?
Old June 2nd, 2008, 01:25 AM   #12
MWWarlord's Avatar
1995 Mustang convertible
MWWarlord will become famous soon enough
It is best NOT to buy used gears. Used gears will have a pre-established wear pattern on them that will not match your car. It could cause you some problems.
Also welcome to MM!
MWWarlord
check out my garage for pics and a complete list of mods.
http://www.tricktuners.com
Old June 2nd, 2008, 01:27 AM   #13
DeMello is an unknown quantity at this point
get a hold of jess@re and see if he has any gears for the 7.5 rear
Just Another Bolt on GT
[IMG]http://i45.tinypic.com/54f5ua.jpg[/IMG]
Stock Longblock - 287/276
Low 12s NA! 10s on the spray?
Old June 2nd, 2008, 01:28 AM   #14
MWWarlord's Avatar
Also so that you know on your car 4.10 gears will give you a 25% increase in rear wheel torque. As for tuner stuff, click the link in my sig...you'll find all you need there.
MWWarlord
Old June 2nd, 2008, 01:28 AM   #15
Forums at Modded Mustangs - View Profile: Jess@RE
Old June 2nd, 2008, 01:30 AM   #16
MWWarlord's Avatar
Great post. Almost word for word what I would have said(the whole post not just this part) + rep for you!
MWWarlord
Old June 2nd, 2008, 01:33 AM   #17
same with gts?
mine gears are in the mial rite now
Old June 2nd, 2008, 01:38 AM   #18
MWWarlord's Avatar
I think so...there is a gear ratio / torque calculator in a sticky in this section. Put in your info...you can see exactly what gains you'll see.
MWWarlord
Old June 2nd, 2008, 01:40 AM   #19
you know the title so i can search for it by any chance?
i typed gear ratio / torque calculator and this thread is all that came up
Old June 2nd, 2008, 01:43 AM   #20
this is all i coudl find...but im goign to bed lol
http://www.moddedmustangs.com/forums...-formulas.html
Threads Similar to: A few questions...
t5 questions motorhead6776 V6 Mustangs 3 February 8th, 2008 11:11 PM
5.0 H.O. questions 83five0 5.0 Mustangs 11 December 24th, 2007 06:57 PM
pi questions gtdan 96-98 7 August 28th, 2007 06:37 PM
new with questions white69stang Classic Mustangs 7 March 11th, 2007 01:59 AM
Have a few questions CSKX27 94-95 9 November 29th, 2006 09:25 PM
