somtimes....i cant stop....
Old June 1st, 2008, 08:57 PM   #1
The soul stealing Ginger
dgt_mustang's Avatar
2001 Mustang 3.8l
dgt_mustang has a spectacular aura aboutdgt_mustang has a spectacular aura aboutdgt_mustang has a spectacular aura about
Send a message via AIM to dgt_mustang Send a message via Skype™ to dgt_mustang
ha, title can be misleading if you read it how you want,
Start the car
Put it in Drive
Driving forward, coming to a stop-sign, try to stop but it slows down extremely slow rather than stopping, after pressing the brake a couple times, it works like its supposed to, whats up with that?
Cosmetic:
Vent-visors, Pioneer Bluetooth Radio Deck, 17" Cobra Alloy Rims, HID 4500k 55watt setup, Chrome Headlamps 15% Tint, Red sway bar
Performance:
CAI,Mac-Longtubes, H-pipe, Flow 40s, NO CATS Diablo Tuner, Rear Sway bar
Old June 1st, 2008, 08:58 PM   #2
Assassin_Dan's Avatar
1998 Mustang V6
Assassin_Dan is on a distinguished road
Send a message via MSN to Assassin_Dan
Sounds like you have air in the brake lines.
Old June 1st, 2008, 09:00 PM   #3
bullitt5576's Avatar
2001 Bullitt
bullitt5576 will become famous soon enough
+2 on air in the brake lines, does it feel soft? and once you pump it a couple times firms up?
MM NEW EDGE COBRA CREW #2
Old June 1st, 2008, 09:03 PM   #4
2001 Mustang 3.8l
yep, thats what it does, but what i dont understand is does the air stay in there? even after pumping?
Cosmetic:
Performance:
Old June 1st, 2008, 09:07 PM   #5
1998 Mustang V6
yes it does, you have to bleed the brake lines the get rid of the air.
Old June 1st, 2008, 09:07 PM   #6
2001 Mustang 3.8l
is there a better time to do it or how do i tell if im doin it right?
Cosmetic:
Performance:
Old June 1st, 2008, 09:14 PM   #7
1998 Mustang V6
You need 2 ppl, one to pump the brake pedal and one guy on the valve and each brake caliper. you start at the farthest barke away from the master cylinder and work up the the closet. You have to pull all 4 tires to this job. You have one guy pump the pedal and the other guy opens the valve and lets the air bleed out, but he has to keep his foot on the pedal so the air doesnt go back in.
Old June 1st, 2008, 09:16 PM   #8
HMUSN's Avatar
iTrader: 9 reviews
I would just take it to pep boys and have them hook you up with new brake fluid.
Your probably due for a change anyway.. bleeding brakes can be a pita and they have a machine that they hook up which gets it done in like 5 mins.
Old June 1st, 2008, 09:16 PM   #9
2001 Mustang 3.8l
how much?
Cosmetic:
Performance:
Old June 1st, 2008, 09:17 PM   #10
HMUSN's Avatar
iTrader: 9 reviews
should be under $50 or so.
Old June 1st, 2008, 09:18 PM   #11
2001 Mustang 3.8l
ill probably end up doing it myself, may be a pita but its not hard right?
edit*
me and my buddy.
Cosmetic:
Performance:
Old June 1st, 2008, 09:19 PM   #12
HMUSN's Avatar
iTrader: 9 reviews
no it's not hard at all. it's just a pita
Old June 1st, 2008, 09:20 PM   #13
2001 Mustang 3.8l
sweet, then ill probably do it myself, did assasin_dan have everything down on that one?
Cosmetic:
Performance:
Old June 1st, 2008, 09:21 PM   #14
HMUSN's Avatar
iTrader: 9 reviews
everything but checking your cap up top to make sure it doesn't go dry (meaning your just getting more air in)
Old June 1st, 2008, 09:22 PM   #15
1998 Mustang V6
It's a little more in depth than that, but i can explain it furthur if you want
Old June 1st, 2008, 09:23 PM   #16
2001 Mustang 3.8l
sweet, i already have some prestone synthetic brake fluid here, new, not opened, the big bottle so ill probably do this tomorrow
how do i bleed it all out without letting the master cylinder go dry?
Cosmetic:
Performance:
Old June 1st, 2008, 09:24 PM   #17
HMUSN's Avatar
iTrader: 9 reviews
by checking your cap up top to make sure it doesn't go dry
Old June 1st, 2008, 09:24 PM   #18
1998 Mustang V6
Keep adding fluid to it
Old June 1st, 2008, 09:29 PM   #19
2001 Mustang 3.8l
sweet, thanx guys imma do this tomorrow, any idea how much fluid would be helpufl i have the synthetic 32oz prestone here, dot 3
edit*
gotta go, tornadoe outside
Cosmetic:
Performance:
Old June 1st, 2008, 09:30 PM   #20
HMUSN's Avatar
iTrader: 9 reviews
buy 2 bottles just to be sure but one should do it.
Threads Similar to: somtimes....i cant stop....
Someone stop me!! Heather The Clubhouse 53 June 2nd, 2008 12:30 AM
anyway to stop nba1341 Classic Mustangs 7 March 25th, 2008 10:47 AM
Can't Get The Leak To Stop... Stop Me From Doing This. militant54 94-95 21 February 27th, 2008 10:17 AM
Stop it Onemanzu The Clubhouse 77 September 12th, 2007 03:20 AM
V6 That Won't Stop! Keir V6 Mustangs 3 October 12th, 2006 04:16 PM
