shift linkage problem
Old June 2nd, 2008, 01:05 AM   #1
homeboy2kfun is on a distinguished road
So my 2001 v6 stang was hit in a parking space at 15mph and pretty messed up. Well i got it all fixed but my shift linkage is all messed up. So i went back and talked to then and they told me i did not know how a mustang drives. I know how my car of 2 years drives thank you. So i was thinking there is a nut or something i can mess with. The problem is it will almost not go into park and drive is in is somtimes second gear its off just by a little bit. can any one help me
Old June 2nd, 2008, 09:30 PM   #2
stephen has a spectacular aura aboutstephen has a spectacular aura about
Yes. If you look at the drivers side of the transmission there is a nut that holds the shift cable onto a lever that controls the transmission. If you loosen that nut and get the transmission and shifter both in park and retighten the nut it should be adjusted right.
Threads Similar to: shift linkage problem
Why get the Watt's Linkage? rockybalboa 2005 - 2010 5 May 13th, 2008 02:05 PM
Throttle Linkage Z28Eater 94-95 0 April 8th, 2008 08:43 PM
Clutch Linkage? fuanfwab 5.0 Mustangs 4 January 2nd, 2008 08:22 AM
FMX to C6 linkage prob aldrew Classic Mustangs 4 February 12th, 2007 12:25 PM
GTO T-56 linkage banini Modular Mustangs 5 September 15th, 2006 08:09 PM
