LinkBack (1) | Thread Tools |
#1
cheap back axle
well i ordered a7.5 Tlock the other day...but i was with my friend at a mechanic shop to get a rearend for his dodge when i set my eyes upon an 8.8 with 4.10 gears n Tlock... he only wants 150 for the complete setup... it came off an 02.... is it worth the money to buy it? and will it bolt up easy?
![]() iTrader: 1 reviews
the whole 8.8 rear with 410s and T-Lock for 150 bucks
if nothings wrong with it woudl be a great deal...but for that price id be iffy about why its so cheap the 410s alone are worth 150 (new)
Just Another Bolt on GT [IMG]http://i45.tinypic.com/54f5ua.jpg[/IMG] Stock Longblock - 287/276 Low 12s NA! 10s on the spray? |
Zoolander
04 Cobra #2260/3768 1/820
i say buy it...sell the parts out of it, and use the housing to hold a 31 spline upgrade. You won't break any of that. Yeah, that may be overkill, but if you plan on over 400 hp for your car then do it. I don't know what your plans are for your car, but the stock 28 spline 8.8 isn't as strong as a lot of people say it is.
well how much would i be lookn at for a 31 setup?
ok correct me if im rong but all i need is the axles... gears... and tlock to do the conversion right
driveshaft
2004 Mustang V6 Vert.
328/419 @ 4000 rpms
and a rebuild kit would make it all new
its not all that cheap im doing it now and i forget but its under 1000.00 for axles differential gears and rebuild kit
and you could throw an eaton posi in it
Zoolander
You don't need a driveshaft for this conversion
This is everything I used for my 28 to 31 spline conversion: 8.8 31 spline FRPP cobra differential 31 spline Moser axles Motive 4.10 gears Master rebuild kit Friction modifier RP Gear Oil and my tuner to recalibrate my speedo |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/73944-cheap-back-axle.html
| cheap back axle | This thread | Refback | June 2nd, 2008 10:23 PM | |
Threads Similar to: cheap back axle
| axle back question | evan | 2005 - 2010 | 18 | April 13th, 2008 10:31 PM |
| Axle Back or x pipe? | SLNGT2007 | 2005 - 2010 | 23 | October 14th, 2007 09:36 AM |
| axle back exhaust | yamahammer | 2005 - 2010 | 6 | August 14th, 2007 01:17 AM |
| axle back | RC02GT | Modular Mustangs | 1 | March 5th, 2007 11:20 PM |
| Questions about Axle back & Cat back exhaust | Scion | V6 Mustangs | 2 | October 9th, 2006 07:44 AM |
