1995 Mustang V6 temperature issues
Old November 3rd, 2006, 09:42 PM   #1
I_CTCHR95 is on a distinguished road
I have a 1995 V6 Mustang and recently have been dealing with some behavior that puzzles me. For a few days, on and off, my car started overheating. It only happened every few days, so I replaced the thermostat. After replacing the thermostat the car hasn't overheated, but after the car has a chance to warm up the temperature will begin to flucuate. This doesn't happen all the time, and never seems to happen when I make my boyfriend drive it. I am aware of the problems that 1994-95 V6s have had with head gaskets, I've already replaced the engine once. The engine I currently have have about 80,000 miles. I'm not losing water, my heat is fine, in fact other than the flucuation the engine feels fine. The only problem I am having is with my muffler, which has begun rattling due to a bad installation. Any ideas or am I out of luck and a lot more money?
Old November 5th, 2006, 10:43 AM   #2
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
what tempeture thermostat did you install? once the vehicle is up to temp can you feel warm fluid being circulated through the hoses? i assume you did a coolant flush when replacing the thermo...did you check to see if there were any air bubbles in the system after replacing the thermostat? make sure your fan is working, also make sure the fins on the front of the radiator are not clogged. might wan't to try replacing the radiator cap, beleive it or not a bad sealing cap can cause numerous problems... and if you said the engine has once been replaced maybe you kept the original radiator and what not...
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Threads Similar to: 1995 Mustang V6 temperature issues
New 1995 Mustang GT dothedew1654 5.0 Mustangs 3 October 21st, 2007 08:29 PM
1995 Mustang Clock issues when head lights are turned on jen25ca V6 Mustangs 16 August 4th, 2007 10:28 AM
1995 Mustang GT 5.0 Josh21 5.0 Mustangs 26 December 17th, 2006 01:35 AM
hey new guy 1995 v6 mustang help mustangklint95 New Members Introductions 3 December 13th, 2006 01:46 AM
3.8 to 4.6 in 1995 Mustang fourweelin 5.0 Mustangs 2 December 10th, 2006 02:56 PM
