Seriously need Check engine light help!!
I recently pulled the codes for my check engine light problem and they were:
po135, po141, po155, po161- o2 heater circuit malfuntion, both banks and sensors. These codes were pulled when I had a stock exhaust on. I just purchase a pypes "the beast" exhaust. What do I have to do to get rid of these codes with this exhaust? po403- Exhaust Gas Recirculation Circuit Malfunction. Do I have to buy a new EGR valve or is it something else regarding the circuit? po446-Evaporative Emission Control System Vent Control Circuit Malfunction. po443-Evaporative Emission Control System Purge Control Valve Circuit Malfunction . I have no idea what these codes mean or do. If anyone has any ideas on how to get rid of all these codes, please let me know. Thanks!!
Modded V6
![]() iTrader: 1 reviews
Get a SCT tuner and turn off the o2 sensor
Modded V6
Ok I lied you can fix it by getting a tuner but you can also fix it by getting a 24" o2 sensor extensions. Read the what it says at the bottom of the product.
http://www.pypesexhaust.com/sys-mustang.html |
1999 Ford Mustang V6
the evap purge valves are notorious for failure, if you do a couple of searches on here you should come across some good posts....
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
#5 | |
14.79 @ 92.15
Did you replace all of the oxygen sensors? These are common maintenance codes. Just replace bad parts with new ones.
Get MIL eliminators or a tune to turn off the rear pair since you have no cats. Then listen to 99mustang232 about the evap purge valve.
Threads Similar to: Seriously need Check engine light help!!
| check engine light | 02ATIstang | 99-04 | 24 | May 22nd, 2007 05:03 PM |
| Check Engine Light | brose1388 | 2005 - 2010 | 4 | April 28th, 2007 03:26 PM |
| 95 3.8L check engine light | nikbait | V6 Mustangs | 3 | February 24th, 2007 02:57 PM |
| Check engine light | ByPopularDemand | V6 Mustangs | 18 | January 9th, 2007 01:50 PM |
| Check Engine Light? | GreenFaleen | V6 Mustangs | 13 | November 20th, 2006 02:26 AM |
