Um, I have a few questions... - Page 4
Old June 7th, 2008, 06:34 PM   #61
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
Originally Posted by 3.8Coastie View Post
they do make 3.55's for the 7.5. that is the gear chris was going for
the 8.8 can handel harder launched than a 7.5 truetrac because of stronger spider gears. you can beef up a 7.5 with a t-lok, but the spider gears are still weak.
4.10s are the best gear for a n/a auto, 3.73 for supercharged auto, and 3.55 for the turbo.
actually im pretty sure they dont make the 3.55s for the 7.5...u can ask chris but i think me and him had a conversation about them not making those for that cuz i was lookin into gettin em for mine, but i think i might just stick with the stock gears and put in a tlok....but then again im not lookin for over 300 horsepower
SCT Mass Air Flow Sensor $200
Old June 7th, 2008, 06:49 PM   #62
mooses is on a distinguished road
No. A stock 8.8 will definitely NOT handle harder launches than a 7.5 with a truetrac. The 8.8 will hold up just fine for these power levels, but it is not stronger than a 7.5 with a truetrac. Putting a tlok in a 7.5 is not 'beefing' it up, the tlok is the weak link.
Built 8.8 > truetrac 7.5 > stock 8.8 > tlok 7.5
Old June 7th, 2008, 06:55 PM   #63
Hard launches are the main killer of tloks. People have broken tloks with power levels just above stock (<180rwhp) because they launch hard. You could have 250 rwhp, but if you never do any hard launches, a tlok will probably be fine.
Old June 7th, 2008, 07:05 PM   #64
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
only hard launches the car will see is just from stop to go...no holding the brake or anything and no slicks...i think it would hold fine
Old June 7th, 2008, 07:08 PM   #65
Tigerwhite1's Avatar
2003 Mustang V6 Auto
Tigerwhite1 is on a distinguished road
Send a message via AIM to Tigerwhite1 Send a message via MSN to Tigerwhite1
ok, so if my rear end doesn't hold up and my tlok (or whatever i get) breaks, could/would it damage anything else?
03 V6 Stang - Auto - Custom gauges (stock at day, red at night )
97 V6 Stang - 04 Drivetrain - Sold for 67
'07 Ninja 650R - Sold for F4i
'95 V6 Stang - 5-speed Vert
67 V8 Stang - Coupe w/ 4bbl 302
'02 Honda CBR600 F4i
'85 Firebird - v6 5spd
Old June 7th, 2008, 09:04 PM   #66
I think you'll be all right then.
Old June 8th, 2008, 11:20 AM   #67
muneris pro ego
Ninjawafers!'s Avatar
97 5.0 Exploder AWD
snow has nuthin on me
Ninjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to behold
Send a message via AIM to Ninjawafers! Send a message via Yahoo to Ninjawafers!
she spider gears are usually the first thing that goes in a rear end. truetrac or not, the 7.5 spider gears wont hold up to what the 8.8 spider's will hold up to
and you are right about the 3.55's... i just googled it and couldnt find them for the 7.5
i did find 3.45's for the 7.5 which would be good with turbo as well... heres the linky
Richmond - Diff Gears - 7.5" -
Buy my M90 Kit and my Gears and T-Loc!
MM ZDC - Alaska Base Commander
MM+ Cleavage Club #24
MM Cares Crew / Military Crew
M2C2 President / USCG - OS2
Old June 8th, 2008, 01:53 PM   #68
ok, thanks coastie i'm think i'll try for the 8.8, if its much more expensive then i'll stick with the 7.5 truetrac.
Here is the list of which i'm thinking about
1. Dual Exhaust w/flowmaster 40's (they cut the y-pipe and run a new pipe on the other side)
2. 8.8 rear end
3. Tuner
4. 3.55 gears
5. Windstar upper intake swap
6. Shift kit
7. Fuel system
8. Ignition
9. Nitrous (75-100 shot)
10. TMA Turbo
11. Brakes (slotted rotors and ceramic disc pads?)
12. Suspension
13. Torque Converter
Old June 8th, 2008, 03:33 PM   #69
Christ, you have no idea what you are talking about. This is completely incorrect. There are no spider gears in a truetrac, it is an entirely different design. Let me put it a little more clear: if you put a truetrac in a 7.5 rear it will be stronger than a stock 8.8.
If you put a tlok in a 7.5, then there is a high chance that the spider gears will break if launched aggressively.
Threads Similar to: Um, I have a few questions...
few questions BWAL 5.0 Mustangs 62 February 5th, 2008 09:25 PM
Questions About T-5 fastford3388 5.0 Mustangs 5 November 27th, 2007 03:16 PM
pi questions gtdan 96-98 21 September 15th, 2007 03:35 PM
I have some 4.2L questions. One Bad Sixxx V6 Mustangs 14 April 8th, 2007 10:14 PM
Have a few questions CSKX27 94-95 9 November 29th, 2006 09:25 PM
