5.0 in V6
Old November 6th, 2006, 01:56 PM   #1
camer is on a distinguished road
Send a message via AIM to camer Send a message via Yahoo to camer
5.0 in V6
I own a 3.8l 2000 mustang. Its a five speed manual. I want to put a 5.0 in it. Will the 5.0 hook up to the v6 five speed manual transmission? th3e 5.0 is a roller cam engine. I really need to knwo cause that is debating weather or not i will be getting a v8 or not in my mustang. Thank you.
Old November 6th, 2006, 04:24 PM   #2
chevy_killer's Avatar
2009 v6 Mustang
chevy_killer is on a distinguished road
Send a message via AIM to chevy_killer Send a message via Yahoo to chevy_killer
do you know what year that 5.0 came out of
Old November 6th, 2006, 04:31 PM   #3
ssajdowitz's Avatar
ssajdowitz is on a distinguished road
The 3.8 and the 5.0 share the same bolt pattern where the bellhousing hooks up.
I know this because I have a flywheel, bellhousing, transmission and clutch from a 5.0 in my 98 3.8. As far as I know, the pattern stayed the same for the split port as did the single port.
Old November 6th, 2006, 04:34 PM   #4
2009 v6 Mustang
but the thing is can the v6 trani handle a 5.0
Old November 6th, 2006, 04:36 PM   #5
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
The aod cannot. those trannies are very weak- which is why ford upgraded to the 4r70w in the later yrs.
ModdedAutos
1999 Mustang V6
Old November 6th, 2006, 04:51 PM   #6
2009 v6 Mustang
i would get a whole new trani instead of hopeing it would fit or if it would hold up the 5.0 power.....im just trying to save you some heart ache......i can see it now if you put that v6 trany in...you go to punch it and the trany fails and your out a trany...then youll have to take the motor back out and swap the tranys when you could have spent the extra money to get you a new trany
Old November 6th, 2006, 06:43 PM   #7
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
can you get the 5.0 and the tranny?? or is this a crate engine your looking at
Old November 7th, 2006, 10:20 PM   #8
Pharoh is on a distinguished road
im thinking about thisi too i already posted but would i be able to bolt a 5.0 motor and 5spd trans right into the 2000 mustang engine bay.
2000 Mustang V6 5spd. (deceased)
1988 Monte Carlo SS (cruiser)
1993 Mustang GT 5spd (bruiser)
Old November 8th, 2006, 12:06 AM   #9
Onemanzu's Avatar
well the thing is if you get a 5.0 your running it threw the weaker 7.5 rear end... to get a scrapped rear end and install it your self might be worth it ... but then again its all your call... if your car has some crazy sentimental value then go for it IMO sell your car in the paper and buy a GT...
Old November 8th, 2006, 12:36 AM   #10
ssajdowitz's Avatar
I'm not sure the AOD is all that weak.
The fox body 5.0s ran an AOD. Also, my 89 Thunderbird Supercoupe also has an AOD. My 92 F-150 with a 5.8L uses an A4OD. Is the A4OD similar?
Old November 8th, 2006, 12:44 AM   #11
14.79 @ 92.15
the aod is much weaker than the 4r70w and has old technology in its construction http://www.becontrols.com/tech/ch2aodefund.htm
ModdedAutos
1999 Mustang V6
Old November 8th, 2006, 12:54 AM   #12
ssajdowitz's Avatar
So, it looks like there are two main improvements.
1)The upgraded overdrive band.
2)The enhanced lockup feature. Sudden lockup will kill transmission quickly. My old AODE lasted only 7k miles with a 3000rpm stall. By installing that, I pretty much eliminated the upgrade.
It looks like the best bet is to install an AODE or 4R70W with a stock converter, unless you upgrade the tranny as well.
To the Optimist, the glass is half full.
To the Pessimist, the glass is half empty.
To the Engineer, the glass is twice as big as it needs to be.
Old November 8th, 2006, 12:58 AM   #13
14.79 @ 92.15
4r70w can withstand 700ft./lbs tq., that is what the 70 stands for.
ModdedAutos
1999 Mustang V6
Old November 8th, 2006, 01:44 AM   #14
ssajdowitz's Avatar
The AODE and the 4R70W are essentially the same except for this:
1)Gear ratios, the 4R70W has the wide ratio gears whereas the AOD-E doesn't.
4R70W ratios are: (1st) 2.84, (2nd) 1.55, (3rd) 1.00, (OD) .7
AODE ratios are: (1st) 2.40, (2nd) 1.40, (3rd) 1.00, (OD) .67
2)The 4R70W has a larger diameter slip yoke on the driveshaft.
3)The 4R70W has a different extension housing.
4)The 4R70W uses better output shaft material.
My car failed the 1-2 band, which is the same for both transmissions. And, I know I'm not putting out over 700ft-lbs of torque. The sudden impact from the stall converter is much higher due to the sudden change in kinetic energy of the converter.
They probably rated the tranny under a load applied slowly.
