Discussing Common A/C Compresser in the V6 Mustangs Forum. 2001 3.8 v6 Ok, so couple months ago my a/c compressor locked up ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2001 3.8 V6
Common A/C CompresserOk, so couple months ago my a/c compressor locked up and burnt the belt off. Took it to a local machanic shop since it was there warrenty work when they put a new motor in it. Since then the compressor has locked up and burnt my belt off AGAIN... My question is, if they dont feel like doing warrenty work, without buying a delete kit which im sure i do because looking at the belt routing when it comes off the tensorner it will hit the waterpump pully when tryin to bypass the a/c with a shorter belt, is there another way to route the belt to bypass the a/c or will i need to buy a delete kit? |
#2 | |
1998 Mustang V6 5 spd.
Welcome to Modded Mustangs,
want that A/C working.
2001 3.8 V6
ok well what if it wasnt warrentyable?
2001 3.8 V6
ok i think i got the config figured out but im not too positive on it....basically all the pulleys in the system turn 1 way and the water pump pully will turn the oposite...like if the crank, alt, ps, ac, tensioner, turn the the right the water pump turns to the left and visa versa....so i made diagrams in paint and i just wanted to get a second opinion.
1994 Mustang v6
slower than your average snail
i dont think thats gonna work....
![]() XBOX TAG- DioMurksAll 1994 V6. red interior, black w/red side/hood scoops and taillights.CAI,Custom X pipe w/FORCE mufflers, 3:73's |
2001 3.8 V6
success =]
01 mustang
Ha, nice drawing but i really dont think thats gonna work, theres definetly no tension what so ever going to be on the water pump if you do that. That water pump will need more, besides, why would you delete the a/c in the midst of summer?
![]() LEAVE REP POINTS WHERE NEEDED!!! 2001 mustang V6 CAI,Tuner,Cobra Rims To come: UDP, T-lok, 3.73, full exhaust setup W/flowmaster 40s, aluminum driveshaft. |
2001 3.8 V6
well when i drew it the tensioner pully is up a lil higher than i drew...but it works theres good tension on the water pump, no over heating, no whining from the belt...but it works, all pullys turn like there supose to. and bypassin the a/c is because the compressor has locked up, and i dont feel like spending an arm and a leg to get it fixed. it wasnt under warrenty
01 mustang
That sucks, well least it worked, i would get it fixed sometime soon either way, i geuss depending on where you live would make a bigger difference though.
2001 3.8 V6
only gets up to about 95-100 here in summer, windows down tho, not that bad...tho leather tends to get hot..
01 mustang
Ha, i bet, well good luck then, get one of those little fans that plug into the cigg port, and aim it at you.
2001 3.8 V6
haha
Threads Similar to: Common A/C Compresser
| 03/04 Cobra common problems | t-man2 | 4V / SVT | 40 | June 2nd, 2008 07:36 AM |
| Something in Common... | oldernewbie | The Clubhouse | 3 | February 21st, 2008 01:24 PM |
| Most Common Gear ? | Montanasvt | 99-04 | 19 | February 12th, 2008 10:31 PM |
| Common guys | Juggalo_X | The Clubhouse | 19 | September 5th, 2007 06:38 PM |
| Is This Common? | mustangmanic | 99-04 | 17 | July 7th, 2007 04:49 PM |
