weak sauce...water pump is leaking...
for some reason my oil pressure was really high so when i got home i popped the hood to inspect and it was low on oil...but i also noticed coolant leaking out of the bottom...crawled under there and at the angle i was at looked it was coming from my crank
but then i reposistioned and noticed it is leaking from the water pump...since theres alot of shit in the way i cant exactly tell if its cracked and its not gushing...right meow its just a drip...any ideas or easy ways to fix it?and surprisingly my coolant is still super bright green hahaha
![]() 94v6.CAI,Exhaust,3:73s-needs rear end rebuild 02GT/Saleen.built motor,62mm turbo 412hp/446tq @10psi,stock TB and intake |
2001 3.8 V6
gasket might be cracked, but hell, even if the water pump was fine and the gasket was messed up, why bother taking everything apart for the gasket when the pump is like 40 bucks....might as well replace it all at 1 time than do a gasket then down the road a water pump. do your self a favor as preventive mantience.
The soul stealing Ginger
meow listen here, normally i would agree with what spyke was going with but if you go down there to fix it and your water-pump is fine and it is the gasket, why bother fixing something that isnt broke? meow thats your choice, but a gasket for water is like 7.99 or something like that.
2001 3.8 V6
well i know those water pumps are a bitch to get to, and theres no point to replace a gasket, then down the road the pump goes out.....pump is like 40ish or something be best to replace it while ur at it.
yea...its weird cause right meow it wasnt leaking...idk if the gasket was just like hey screw you for a second and sealed up or what....but if i think i need a new timing chain so if i was gonna do that sometime then waterpump will be most def as well...so much shit with no garage...sucks....ill keep you posted if it gets worse or what not..
#6 | |
put cement on the coolant and call it done easy fix man
{no ppl dont do it} do as the above mentioned lol
Threads Similar to: weak sauce...water pump is leaking...
| Leaking antifreeze/pump prob!!! | Olita 1 | 5.0 Mustangs | 6 | February 5th, 2008 12:20 AM |
| 68 mustang leaking water... | willislegend | Classic Mustangs | 2 | September 4th, 2007 10:40 PM |
| water leaking into floor | mattstang | 99-04 | 1 | August 10th, 2007 12:25 AM |
| Car leaking water front drivers side | Timmano | V6 Mustangs | 5 | May 23rd, 2007 01:39 PM |
| Focus Leaking Water Into Passenger Floor | OTreborO | All Other Vehicles | 4 | November 9th, 2006 11:15 AM |
