cooling problems
Old June 13th, 2008, 02:22 PM   #1
mickchu is on a distinguished road
cooling problems
My car is a 1995 V6 manual. On running in heavy trafic without my AC on the water temperature will red-line. If I put the AC on it is OK. I checked under the hood and the fan comes on when it gets to temperature but will switch off when it gets hot. This fan does come on when the AC is put on. I did have to replace my computer for another problem but my cooling problem is still there. Any ideas?
Old June 13th, 2008, 03:17 PM   #2
Baker02125's Avatar
2000 Mustang
Baker02125 has a little shameless behaviour in the past
check your oil you may be low, check your coolant and you may need a new thermostat heres a good link
180 Degree Thermostat in a 3.8L V6 Mustang
Old June 13th, 2008, 09:33 PM   #3
BostonPerformance's Avatar
99 Cherokee sport/87 5.0
not tested
BostonPerformance is a jewel in the roughBostonPerformance is a jewel in the roughBostonPerformance is a jewel in the rough
+1 on the thermostat. I put a 180 in mine as soon as i got it, and now the dial stays on "c"
Old June 14th, 2008, 09:03 AM   #4
checked the oil many times. Put at least two new thermostats.
Old June 14th, 2008, 11:11 AM   #5
94v6blkndred's Avatar
02 Turboed Saleen Clone
faster than my v6
94v6blkndred will become famous soon enough
Send a message via Skype™ to 94v6blkndred
check your ECT/CTS.....sensor could be messin up so your THINKING your car is overheating and cooling funny but it may be perfectly fine...
http://www.dewayneamiller.com/uploads/94v6blkndred_sig.jpg
94v6.CAI,Exhaust,3:73s-needs rear end rebuild
02GT/Saleen.built motor,62mm turbo 412hp/446tq @10psi,stock TB and intake
Old June 15th, 2008, 09:38 AM   #6
I have a secondary water temperature sensor and an oil temperature senser. They both says that I am overheating.
Old June 15th, 2008, 09:40 AM   #7
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
you would be better off running your heater fan than your AC fan to cool it.
Old June 15th, 2008, 01:22 PM   #8
stephen has a spectacular aura aboutstephen has a spectacular aura about
Sounds like the fan control circuit is the problem. It is overheating in traffic because the fan isn't coming on. The A/C makes the fan run. You need to find out why the fan doesn't come on with the engine hot but A/C off.
Threads Similar to: cooling problems
cooling fan problems fast5.0lx 4V / SVT 1 April 9th, 2008 09:40 PM
Cooling problems suburban_concepts 5.0 Mustangs 9 October 21st, 2007 11:14 PM
cooling problems RyanGT 99-04 30 August 16th, 2007 07:42 PM
Radiator Cooling Fan Problems jagstang96 96-98 1 October 15th, 2006 05:05 PM
Cooling Fan Problems rene9 96-98 6 September 26th, 2006 06:29 PM
