Discussing Strange Ignition/Radio=WTF? Problem in the V6 Mustangs Forum. Two days ago on the way from my friends house I noticed I was having ...
Old June 15th, 2008, 03:50 PM   #1
Two days ago on the way from my friends house I noticed I was having some wierd problems. First I noticed my radio was cutting out every time I gave the car any throttle, it would break up, kind of like if your listening to a radio station that doesnt come in well, its not a radio reception problem as it happens on CDs and my IPOD as well. The radio doesnt dim or anything, it doesnt appear to be losing power, my subs also still seem fine and my car lights dont dim when it hits indicating its not an alternator problem as some people have told me. Thats only part of the problem, the other half and the more importent half is my car is slow, sluggish, and sputtering. It feels like its not firing properly on all cylinders. The car is jerky when im accelerating or cruising on throttle. Both of these problems started happening at the same time so it makes sense that they would be related. I dont have any clue what could be causing this nor did most of the people I have talked to so any help is appreciated.
Old June 15th, 2008, 11:02 PM   #2
Mod Johnson
WLJohnson05's Avatar
2004 Mustang V6
before my alternator went out my radio started cutting out and such along with my gauges dying. then my car started sputtering like it was dying. remember if the ecu doesnt have the power to control everything ur car isnt gonna run right. so i wouldnt totally cancel out an alternator problem
Originally Posted by Onemanzu
put the shiny thing next to the dudad and get this thingymagigger and connect it to the hoptey dooo and your all good
i wish my name was woody johnson, damn. lol
TURBO on 3.6psi
CHECK OUT MY WEBSITE
Old June 15th, 2008, 11:33 PM   #3
The thing is everything seems like its getting enough power, the radio isnt dimming or anything, it just doesnt sound right. I drove the car today and the car actually seemed worse, especially when idleing in gear, it was chugging kind of like when you hear a car with a crazy cam setup.
Old June 15th, 2008, 11:41 PM   #4
Mod Johnson
2004 Mustang V6
is it idling low?
TURBO on 3.6psi
Old June 15th, 2008, 11:46 PM   #5
It hasnt been but today when it was in gear it did and then it stopped doing it when I came to the next light.
Old June 15th, 2008, 11:59 PM   #6
Mod Johnson
2004 Mustang V6
have you tried cleaning the maf and other stuff like that?
TURBO on 3.6psi
Old June 16th, 2008, 06:33 PM   #7
You might check the radio capacitor, which is near the coil. If it's shorting out intermittently it could account for the symptoms.
Old June 17th, 2008, 11:44 AM   #8
'00 3.8L
This answer only concerns the radio; I had previously had subs/amps in my car, and when I removed them, left all the wiring in place. I began having the same problem as you described with the radio/cds going out. Once I removed the old remote wire that went to the no longer existent amp, problem solved. Just a thought if you have/had a sound system.
"Fast she goes...in the City of Overdose"
Old June 17th, 2008, 05:45 PM   #9
Blackbeauty v601's Avatar
2001 Mustang 3.8
this is for the sound system only.... How are the wires run in your car from the battery to the amp? by wires i mean RCA cables, Remote wire, and your power wire? are they all on the same side or did you separate them. the rca cables should be run by them self or they can pick up interference from the power or remote wires and put out a annoying sound from the speakers. also you may have a short in your power or remote that is messing it up also.
SCT Xcal 3 tuned,4.10 gears, T-lock, J-mod, CAI, dual flow masters.
Old June 17th, 2008, 08:41 PM   #10
There both on the same side however I ran it like this for 6 months with no problems, I had my old car wired up the same way.
Old June 17th, 2008, 08:42 PM   #11
I guess Ill try removing the remote, it worked fine for 6 months though and that still doesnt explain the ignition
Old June 19th, 2008, 12:57 AM   #12
Today I was driving like an ass because I was late to pick up a friend of mine and the check engine light started flashing. On the way It went back off, car still runs like shit though. Im gonna try and get my codes checked again tommorrow, Im just afraid that with the light off again they wont find it again.
Old June 19th, 2008, 01:02 AM   #13
Editor
2000stang's Avatar
1964 Ford Fairlane 351C
9.64@147.37
Location: in HB's basement helping with the rocket...waiting on zip to deliver the fuel.
2000 Mustang Workshop Reference
this will help with your codes
slow car club - crew member 6 of 9
Hoof beats are louder than Heartbeats
Cat Club Co-Founder
MM Snowmobile club (founder)
Threads Similar to: Strange Ignition/Radio=WTF? Problem
ignition problem with my other vehicle 92_LX_5.0 5.0 Mustangs 2 November 8th, 2007 10:15 PM
strange problem with guages - electrical experts? 2kGT 99-04 5 October 10th, 2007 08:35 PM
is there anyway to get away for the ignition problem gordon norris 5.0 Mustangs 4 February 19th, 2007 09:34 PM
Strange Heater Problem thomas2 General Tech 3 February 18th, 2007 01:10 AM
Ignition problem? 86blkmustang 5.0 Mustangs 15 February 7th, 2007 08:55 PM
