Discussing Traction Lok installation instructions please in the V6 Mustangs Forum. If anyone has or knows where I can get a pretty much step by step ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2003 Mustang Convertible
Traction Lok installation instructions pleaseThank you very much email:a99hd88@hotmail.com |
Where do you live? I would help you out (probably charge a pizza or two for the family) if you're in range. The install is not easy, but not hard. Some ?'s though. Are you keeping the same gear set? Upgrading rear brakes? Do you have a rear rebuilt/install set?
Pull axles. Take out old diff. Match shims to new diff. Swap ring gear to new diff. Place new diff in and check backlash. If that is over shim against, if it is under shim away (referencing the pinion). If good (not likely on the first go) check the pattern. If that's good (actually it usually is if the gears weren't swapped too) put axles back in. Those are the super simplified cliff's notes. Backlash I like at 8 some like more some like less. I know this doesn't help allot, but when you go to do it let me know and I'll try to be available for ?'s. I would go ahead and swap all bearings and seals you uncover (axle, diff, maybe pinion if you need to change the depth) as you are already in there. It also makes a great opportunity for a Cobra or Mach I brake swap too.
Marines: Giving the enemy the opportunity to die for their cause since 1775. Guns: Giving us freedom since we learned how to shoot Mustangs: Giving gearheads a reason to exist since 1964 Turbos: Giving me a reason to appreciate all the above. |
#3 | |
Mod Johnson
2004 Mustang V6
in other words, if u dont know how to do it already then ya shouldnt attempt it most likely
CHECK OUT MY WEBSITE |
01 mustang
get a shop to do it, last thing you want to do is mess something up while your in there and cause yourself alot more problems then the job is worth.
![]() LEAVE REP POINTS WHERE NEEDED!!! 2001 mustang V6 CAI,Tuner,Cobra Rims To come: UDP, T-lok, 3.73, full exhaust setup W/flowmaster 40s, aluminum driveshaft. |
Blown 03 GT
Its really is a bitch, plus all the tools u need start addin up to a pretty penny. Get some subframes welded in when they do the gears.
#6 | |
2000 Mustang V6
unknown @390
the instructions listed on here so far is VERY VERY simiplified. i mean EXTREMELY
i've done this twice and i HATE it. I do not do rear end work on anyones car at all but mine and even then i dread the fact i need to. If your just doing a posi thats not bad. if your swapping gears you'll need a few other tools heres a some up of whats needed to be done. -take off wheels -take off brakes including disc. once the disc are off go under the car and start unbolting the diff. cover. save one last bolt on the top of the cover and get a pan to put under. you might need a flat head or a pry bar to break the seal on the cover and diff itself. let the smelly fluid drain theres a pin that goes through the middle of the stock carrier(the old non-tlok unit) unbolt it. you'll probably need to take out the diff. main caps on the sides to get that bolt holding the pin through the old open diff. when you take off the main caps MAKE SURE that you remember which side goes where and how the cap is facing. its VERY important it goes on EXACTLY how it came off. take off caps take out the bolt then the pin. onces that pin is out go to 1 side of your rear end and push the axle in then go back under the car and with a magnet pull the C clip off the axle do the same with the other side you can now pull out both axles also remember where the c clips and axles go. now you can pull out the old diff use a pry bar to get it out. its going to be a little hard due to bearing preload and how stiff it needs to be with the diff out take off the ring gear now with the new t-lok use thread locker(locktite) on the ring gear bolts and tighten to specs. i dont remember the specs off hand heres the fun part. you'll need to place the diff in with the shims and the correct amount on each side hoping your backlash is somewhat close to correct it should be pretty hard and tight to get in there. if it slips in take it out and put more shims, you will NEED a shim kit if it just slips in your bearings will fail prematurely due to incorrect bearing preload. once you've gone through hell with that and your back lash is correct go ahead and torque down your main caps using locktite on those bolts as well AND putting it back just as you took it out tighten to specs push the axles in put on C-clips put w.e pin or contraption they have for keeping space between both axles in the middle of the diff then put some RTV on the housing. bolt on the cover i think its like 12ft lbs then refill with the CORRECT fluid and posi-fluid then thats it re-install the disc and brakes and wheels |
#8 | |
Ah Ha ! I knew there would be someone out there that knew what I was looking for. Thank you Mr. itschristorres8 ! That was just enough to ring some bells from yesterday gone by and I think I can get the torque settings for all the different bolts from my Chilton Manual. I've already bought some Synthetic gear lube and friction modifier etc... I'll need to fetch some shims from some place but it looks like I'm good to go. Thanks again, Almighty Moddedmustangs friend ! You're very cool for taking the time out and helping me with this task!
#9 | |
I've done more rears than I like too, mostly for friends. Generally it is a good five hours in my garage. Most times it's bearings which is why I like to see all of them changed if someone is pulling the diff/pinion out. Otherwise it's like rebuilding a motor with the old rod bearings. nothing good comes of it. Unfortunately, I tend to get the ones that have been ignored or abused. In fact, could someone explain how this was driven to me (see pic)? It was the worst I've seen still be driven (sort of) And he thought I'd get it done before I went to work!!! He got REAL lucky that the first set of shims went right every where! That was a first for me. It's funny that these people are never around when I need a hand. Maybe I need to start being "busy with the kids" more.
1998 Mustang V6 5 spd.
Best of luck friend, hope all goes well for you!
As long as you can still work on your hobbies & such, you should still have some more life in you! Post back your results.
#11 | |
They would probably just get in your way though!
#12 | |
2000 Mustang V6
unknown @390
and yes ALWAYS replace the bearings and races when doing the install, my bearings had only maybe 3,000 miles since the last time i changed it, but i changed it anyway also because i new the t-lok was broke to hell and metal would be in there but yeah i'd say it takes a good 3-6hours. if its your first time expect easily 5+hours I did my tru-trac in 4hours but got lucky as i mentioned |
#13 | |
Nah, I could always use a tool b!+ch. Besides, I get a free meal for the family out of it when I do work for them. Feeding us takes a couple party pizzas!
#15 | |
), I think I finally found the best forum. Thanks to all for your input. I was born Mechanically inclined with a analytical brain. I scored high on my first mechanical aptitude test for the Army when I was a teen. I've been a mechanic, a building maint tech, an electrician, and a Computer/Network engineer. I'm 50 and Disabled as a Tech Manager. I hope the pain pump they put in me next week will allow me to return to work but they told me not to get my hopes up - how's that for a positive attitude coming from your Dr's assistant - ding dongs !
Threads Similar to: Traction Lok installation instructions please
| Traction-Lok? | The Novice | 5.0 Mustangs | 4 | April 15th, 2008 06:15 PM |
| instructions for camberbolts | leebunnyz | 2005+ | 4 | October 18th, 2007 08:20 PM |
| Intake Instructions | Nick_Rapitis | V6 Mustangs | 21 | June 3rd, 2007 02:50 PM |
| need instructions | tdurbin | 5.0 Mustangs | 0 | May 12th, 2006 09:15 AM |
| Installation of a 7.5" Trak-lok Diff | 99mustang232 | Suspension | 1 | November 27th, 2005 09:14 AM |
