Discussing Cams in the V6 Mustangs Forum. What are they, what do they do, what kind of aftermarket options are there for ...
Old June 18th, 2008, 12:06 AM   #1
El33tist's Avatar
01 focus/ 87 gt
faster than ur 6r/ not tested yet
Cams
What are they, what do they do, what kind of aftermarket options are there for them?
Old June 18th, 2008, 12:19 AM   #2
2000 Mustang V6
unknown @390
http://www.rehermorrison.com/images/...n/Camshaft.jpg
is a camshaft
on our cars and all other OHV(over head valve) motors the camshaft is located in the block between the V
rides and circular cam bearings with drilled holes so oil can get to it and lubricate it
the camshaft opens and closes the valves in your cylinder heads
in a OHV motor also known as push rod motors lifters ride onthe camshaft
as you can see in the picture the camshaft and circular and ovalish looking parts...the oval looking part is called cam lobe. theres a circular part that when the lifter rides on that the valves are shut. not letting air in or out
when the raise section comes up that lifts up the lifter, which lifts up the push rods, the push rod then lifts up one side of the rocker arm and just like a see-saw the other side of the rocker arm must go down in-turn pushing down on the valve.
what makes the valve go back up?
valve springs, the valve springs push the valve back up so it does not stay open and rides smoothly along the cam
proper valve spring choice(tension) is important to much tension will wear the cam lobes prematurely
getting a performance camshaft will usually increase the lift and how long the lift is
a longer or taller lift will allow more air in
the longer the duration of the lift the longer the valve stays open allowing air to enter or exit
regrind camshafts basically grinds the camshaft lobes to a desired spec. now witha regrind longer push rods are needed to make up for whats been grinded down
a new cam will let you keep the stock push rods but whose to say they're strong enough?
new camshaft uses most likely a stock diameter lobe and just increases lift/duration over stock specs for more power
www.crtperformance.webs.com
Old June 18th, 2008, 12:20 AM   #3
2000 Mustang V6
unknown @390
things to upgrade with a camshaft
rocker arms and valve springs
a good idea to replace
push rods
lifters and timing chain and tensioner to avoid having to do it in the future
Old June 18th, 2008, 12:39 AM   #4
El33tist's Avatar
01 focus/ 87 gt
bit beyond my know-how at the moment. I want to go to college for automotive technology at st phillip's here in s.a...
I've decided just to go with a 4.2L setup.
I've got it on good word that I can run w/ a 5.0 if I can just find a 4.2L engine to get parts off of...
Old June 18th, 2008, 07:26 AM   #5
dgt_mustang's Avatar
01 mustang
.......run with a 5.0 with a 4.2 setup.....is there something in addition to the motor cause i doubt a 4.2 with just basic mods will.
LEAVE REP POINTS WHERE NEEDED!!!
2001 mustang V6
CAI,Tuner,Cobra Rims
To come:
UDP, T-lok, 3.73, full exhaust setup W/flowmaster 40s, aluminum driveshaft.
Old June 18th, 2008, 11:46 AM   #6
2000 Mustang V6
unknown @390
maybe a fully built 4.2L
depends what 5.0 your talking about
bone stock yeah you'll crush it
h/c/i no n/a 4.2L can keep up with a h/c/i 5.0 in a n/a vs n/a race
Threads Similar to: Cams
Comp Cams SPR stage 2 cams on the way!!! RStrick0352 2005+ 10 August 9th, 2008 02:06 AM
P.I. Cams Cams Cams Cams Lol Sorry About That 96GtGoodz 96-98 4 December 14th, 2007 09:42 AM
Pi Cams vs. NPI cams ModMustang97GT 96-98 9 September 13th, 2007 05:34 PM
Best Cams hubba076 99-04 11 May 23rd, 2007 09:13 AM
Where do i get cams? Cesar2cool V6 Mustangs 8 April 24th, 2007 09:41 PM
