Discussing split port swap. in the V6 Mustangs Forum. ight well i was planning on buying a split port swap from torres but since ...
Old June 18th, 2008, 02:41 PM   #1
riddlee josh's Avatar
1998 mustang 3.8l v6
split port swap.
ight well i was planning on buying a split port swap from torres but since he no longer sells them i will get it from ssms. but i can't find a kit on their site that says split port swap. what do i need to get from ssms to get all the parts i need for a split port swap?
1998 mustang v6,UD pulleys,msd 8.5 mm wires
shorty headers no cats H pipe flowmaster knock offs cold air intake w/ k n filter
headlights mirrors
2 10 xplod subs
1000 watt amp
Old June 18th, 2008, 03:12 PM   #2
can i atleast get a full list of everything i need for a split port swap? i mean everything.
has anyone tried going to a junkyard and asking for these parts?
headlights mirrors
2 10 xplod subs
1000 watt amp
Old June 18th, 2008, 04:23 PM   #3
2004 Mustang V6 Vert.
most of the junk yards you go to are you pull the parts, you will need :
-99+ mustang v6 heads (including valves/springs)
-99+ mustang v6 upper intake **
-99+ mustang EGR tube and valve
-99+ Throttle Body
-TPS sensor for TB (1-CX-1488 from Ford) if not already on TB
-Throttle cable from 99+ mustang v6
-Modified fuel rail that has a universal fuel pressure regulator, and a return line. (available from SteveC) ***
-Accelerator Bracket (F4SZ-9728-B) if not already included on upper intake
-99+ mustang v6 coil pack and wires (your stock coil pack will work too)
-99+ mustang intake tube, or any 99+ mustang CAI kit
-99+ mustang cooling hoses (including the ones going to the heater core) and pipes. You can also make your own lines, by using plumbing elbows,hoses and clamps, and fab it up yourself. (Definately get these if you can.)
-16 a.w.g automotive electrical wire
-teflon tape, pipe sealant, RTV
-99+ head bolts/studs
-head gaskets (I recommend 99+ mustang gaskets)
-99+ upper and lower intake manifold gaskets.
-99+TB gasket
i think thats everything, but i could be missting something.
2004 Ford Mustang V6 Convertible
Hoping to make 500 RWHP
Motor : Mik @ http://rpm-mustangs.com
Turbo : Andy @ http://tmaturbo.com/
Intake : Chris @ http://www.crtperformance.webs.com/
Transmission : Darrin @ http://bc-automotive.com/
Old June 18th, 2008, 08:47 PM   #4
ight thanks. i think im gonna try to go to a junkyard and try to get the stuff i can.
headlights mirrors
2 10 xplod subs
1000 watt amp
Old June 18th, 2008, 09:07 PM   #5
no problem, you just need to make sure these parts are off a v6 mustangs from 1999 - 2004 and buy New gaskets. whatever you cant find just let me know.
Old June 18th, 2008, 11:26 PM   #6
ight thanks will do
headlights mirrors
2 10 xplod subs
1000 watt amp
Old June 19th, 2008, 12:11 AM   #7
6banger96's Avatar
1996 Mustang V6
at ssms its under the garage sale part for the kit i think
Old June 19th, 2008, 12:15 AM   #8
hey it is thanks that is what i was looking for. not sure i will get it there but i wanted to know the price. thanks man you def get rep. and also rep to plove for the list thanks guys
headlights mirrors
2 10 xplod subs
1000 watt amp
Old June 19th, 2008, 12:49 AM   #9
ok guys i've been thinking. if i get a split port swap it will prob be with parts off of a car at a junk yard. not ported and polished just the way they are stock. and it would cost me a good bit. so would it be better for me to just get my intake and heads ported and polished then save for a cam rather than get a split port swap? which would give me the most gains?
headlights mirrors
2 10 xplod subs
1000 watt amp
Old June 19th, 2008, 12:50 AM   #10
2000stang's Avatar
1964 Ford Fairlane 351C
9.64@147.37
Location: in HB's basement helping with the rocket...waiting on zip to deliver the fuel.
i heard that you should get new head bolts/studs when you swap heads. or will it be ok?
slow car club - crew member 6 of 9
Hoof beats are louder than Heartbeats
Red Mustang Society
Cat Club Co-Founder
Old June 19th, 2008, 12:54 AM   #11
2000stang's Avatar
9.64@147.37
id still say split port cause later down the road you save up then you could have the split port p&p'ed and throw in cam also and have more power.
Red Mustang Society
Cat Club Co-Founder
Old June 19th, 2008, 01:01 AM   #12
what kind of gains will i get from porting my single port?
headlights mirrors
2 10 xplod subs
1000 watt amp
Old June 19th, 2008, 01:15 AM   #13
2000stang's Avatar
9.64@147.37
im not sure chris should know.
Red Mustang Society
Cat Club Co-Founder
Threads Similar to: split port swap.
Split Port Swap 98stangv6 V6 Mustangs 14 May 11th, 2008 01:38 PM
split port swap mannymustang V6 Mustangs 20 April 18th, 2008 02:14 AM
split port swap ? theyanks904 V6 Mustangs 4 March 27th, 2008 08:20 PM
Split port swap justinsstang V6 Mustangs 28 February 5th, 2008 04:56 PM
Split port swap Phatthwag V6 Mustangs 16 May 23rd, 2007 07:44 PM
