Forced Induction
if i wanted to supercharge a 98 3.8, what are some of the things i should do to "prepare" my enigine...
i was thinking UD pulleys Ignition coil new plugs 8.5 msd wires 24# injectors SCT Xcal2 headers and exhaust CAI TB P&P the heads and new cam anything else? |
would i have to rebuild and P&P the heads?
or is it unneeded? |
You do not want to run underdrive pulley's with a vortech or procharger, as that will cut down on the boost you get. The Vortech and Procharger run off the serpentine belt system on your vehicle. I am not sure on other makes of Superchargers though...
1999 Ford Mustang V6
14.79 @ 92.15
only thing you need is an oil feed for most superchargers, fuel pump, fuel injectors, tune.
a cai is not able to be used with a s.c
#5 | |
http://www.moddedmustangs.com/forums...ehicle&CID=496 you do use a CAI with the Eaton M90 |
#6 | |
should i just get my existing pulleys refinished.... |
#7 | ||
not very familiar with forced induction... always built N/A |
Zoolander
04 Cobra #2260/3768 1/820
That has been fabbed up by himself. He did the eaton m90 swap, and then did some extra some stuff. Also all superchargers require stock pulleys. All s/c run off the serpentine belt, and u/d would just make it harder to create boost, and more power.
¡ʇsnq ɹo uʍop ǝpısdn
dude depending on how much boost you wanna run you will have to rebuild the rotating assembly meaning the rods and pistions...
fuel pump was said right? i think thats most of it
If your going to spring the cash on a supercharger, the extra investment in properly building up the lower end of the motor is not hard to swallow... and it is a VERY good investment.
I've run B&M blowers on several older chevy/ford vehicles, and I've seen what happens when you put lots of boost on a stock motor... and it isn't pretty..... |
The stock hypereutectic pistons don't hold up very well. With a base tune, my stock lower end only lasted for 1 hour. The piston pins pulled through the bottom of the pistons leaving me only 2 flat discs of piston left. (cylinders 1 and 4).
And yes, the CAI (like most of my car) is a custom job. But, a lot of Thunderbird Supercoupe performance parts will fit if you do an m90 swap. A centrifugal supercharger (procharger or vortech) will be much much easier to install than a roots style (m90). But, I'd have to agree with most everyone else on this site. Build the base engine as strong as you can the first time, it's much better than having castastrophic failure later.
To the Optimist, the glass is half full. To the Pessimist, the glass is half empty. To the Engineer, the glass is twice as big as it needs to be. |
14.79 @ 92.15
and centri chargers cannot use a bolt on cai like an n/a motor can...
Threads Similar to: Forced Induction
| forced induction | Elder | 96-98 | 10 | October 24th, 2007 09:37 PM |
| Forced induction? | shroom | 99-04 | 4 | June 2nd, 2007 01:20 AM |
| NOS vs. Forced Induction | zkid01 | 99-04 | 29 | April 10th, 2007 05:18 PM |
| Forced Induction | Mustang RacR94 | V6 Mustangs | 30 | March 28th, 2007 11:06 AM |
| Forced Induction FUn | trueballerisme | V6 Mustangs | 122 | February 28th, 2007 02:27 AM |
