Discussing Intercooled Turbo In My 3.8L in the V6 Mustangs Forum. I want to put an intercooled turbo into my mustang. I have heard that the ...
Old November 9th, 2006, 12:49 PM   #1
I want to put an intercooled turbo into my mustang. I have heard that the most psi that my stock fuel injectors can handle is 4.5 psi. Is this true? I wanted to maybee get new fuel injectors with my turbo kit so i could run more pounds of boost. Is it nessesary to put a boost controller in my car?
Old November 9th, 2006, 01:19 PM   #2
Depends on what year 3.8, but I would go with the manufacturer's recommendation on replacing your Injectors. I know that a couple supercharger kits come with recommendations on boost based on the injectors you have in the vehicle.
as for boost controller, it is not really NESSESARY to put it in, as it is generally optional on most systems. However, it will allow you to adjust the amount of boost your system is able to make from inside while driving (depending on model, if it is electronically controllable) or from under the hood with simple adjustments.
Old November 9th, 2006, 01:19 PM   #3
scubasteve041186's Avatar
2004 mustang 40th annv.
k so first things yeah you can put more boost in but it;s not recommened with stock internals, you might break something. and the boost control it;s just nice to have but really depends on how much more boost you want to put in. anyways good luck
Old November 9th, 2006, 01:21 PM   #4
Moderator
Cricket's Avatar
8.876@80.013 1/8th
Talk to andy over www.tmaturbo.com He will prob recommend some 42lb injectors. Like what cyber said a boost controller isn't neccessary, but it is helpful. Also if you want to run a lot of boost better be safe than spending more money to fix your engine. Invest in a turbo timer. It safely cools the oil and runs it where it needs to be ran before shutting the engine off.
Originally Posted by 232stang
...and then cricket put in his $0.03 because hes above $0.02
Blue Mustang Society Member #001
click it
Old November 9th, 2006, 01:24 PM   #5
the early 3000GT's had a major problem with people hotrodding the hell out of them on the highway and then going home and shutting the motor off.... caused major problems..... Turbo Timer is a VERY nice thing to have.....
Old November 9th, 2006, 02:52 PM   #6
yeah the stock injectors can handle about 7 lbs of boost at the most. But if your going to spend the money on a turbo you might as well do it right and spend the money for some bigger injectors
Old November 9th, 2006, 09:24 PM   #7
99mustang232's Avatar
1999 Ford Mustang V6
one of the site's sponsered vedors has a twin-turbo v6 mustang that is running with stock heads, cam, and bottom end. it put down a 10.9 so??? read about it and watch vids on their site: http://www.vmptuning.com/store/index.php?
...even fire and single cammin
Old November 10th, 2006, 03:13 AM   #8
97TunedMustang's Avatar
i would say in a turbocharged setup a boost controller is very necessary. most t3/t4's have a 6-10lb waste gate spring. it just depends. and if your wanting to run less then six it simply wont be possibly and if you want to change it, also not possible if your just using the turbos internal wastegate to regulate boost. buy a boost controller and make it a halfway decent one, if its a piece of crap you can get boost spikes and damage your engine real quick. A turbo timer is also a good idea for a boosted car if your running over about 10lbs of boost, anything less its not as big a deal.
New block with forged internals running 16psi, tuned by Lasota Racing
Too many mods to list...
3.73's and Truetrac Finally Done!
Water-methanol injection?
Dyno Tune fo sho, Street tune FTL!
Threads Similar to: Intercooled Turbo In My 3.8L
PipeLine Intercooled Single Turbo System V6 (2005-2006 4.0L) 99mustang232 V6 Mustangs 15 September 8th, 2007 04:02 PM
tma twin turbo, or procharger intercooled supercharger? 94pacecarSVT Poweradders 7 February 24th, 2007 12:55 AM
Anyone have a Paxton/intercooled kit on their car? Bossman 2005+ 19 December 18th, 2006 12:25 AM
V6 Intercooled Turbo Kit camer V6 Mustangs 3 November 18th, 2006 02:58 PM
FS: Procharger P1-SC Intercooled Drgnracin72 For Sale 89 October 20th, 2006 02:12 AM
