Discussing 2001 Mustang misfiring in the V6 Mustangs Forum. i still say check the resistance of the wires before you go get a coil ...
Old June 24th, 2008, 11:33 AM   #21
Stang Tech's Avatar
1999 Mustang 3.8L V6
i still say check the resistance of the wires before you go get a coil pack
Ford Certified Tech
Land Rover Certified Tech
Ase Certified Tech
Honda/ Acura Certified Tech
AllData Automotive Information Specialist
1999 3.8 V6
35th Anniversary Edition, 4R70W trans
Old June 24th, 2008, 11:37 AM   #22
I was thinking of getting new plugs and new wires and changing them again. Just in case the ones I just got were bad. Do the coil packs just suddenly go bad sometimes? Are they easy to replace? Other than that I was going to take it back to Carmax to have them try to fix it...just dont want them to pull some crap about having to change the wires and plugs and charge me 350 dollars for it. Everything else MIGHT be coverd under my warranty.
Old June 24th, 2008, 11:43 AM   #23
dgt_mustang's Avatar
01 mustang
so change your plugs, wires, and then take it to them, they charged a buddy of mine 175 for changing the plugs and one wire on his 02 mustang. coil packs are easy to replace, its where you connected your wires to near the intake, it just bolts on and off,
LEAVE REP POINTS WHERE NEEDED!!!
2001 mustang V6
CAI,Tuner,Cobra Rims
To come:
UDP, T-lok, 3.73, full exhaust setup W/flowmaster 40s, aluminum driveshaft.
Old June 24th, 2008, 04:29 PM   #24
My 01 is doing the same thing..........i hit water and now it misses when I punch it. New plugs and wires have not fixed it. A guy told me it could be the crank sensor but I have not tried it yet. I have no codes popping up either.
Old June 24th, 2008, 04:44 PM   #25
01 mustang
scary how this is common......i have an 01 and actually bottomed out in water one time during a very very unexpected rainfall, but nothin happened with mine.
tmnmatt have you changed the plugs from bosh to something else?? no joke, it is more than likely the bosh plugs at this point.
2001 mustang V6
To come:
Old June 24th, 2008, 04:51 PM   #26
If I have time Im going to tonight...I will let you know when I do. I think I might change the wires and ignition coil as well.
Old June 24th, 2008, 05:54 PM   #27
01 mustang
k, definetly let us know, that seems to be a huge issue on here with alot of people, i just never realized it. instead of buying that coil see if they will let you just hook it up real fast, that why you dont go through a buying process then a return if it doesnt work.
2001 mustang V6
To come:
Old June 24th, 2008, 07:40 PM   #28
Alright well I found out today on my car that its cylinder 6 thats not firing at all by disconnecting and reconnecting the wires until it didnt change anything. I put in a new coil pack and im having the exact same problem still. I also changed the plug on cylinder 6. Originally I was having the same problem as these guys, sputtering under acceleration on cylinder 1, now my car barely even runs so I dont know if cylinder 1 is fixed or not but cylinder 6 is dead. Im not getting anything from it. Anyone have any ideas??? Im completely out of ideas here.
Old June 24th, 2008, 07:51 PM   #29
01 mustang
how did you find out?? light was on or you felt it?
2001 mustang V6
To come:
Old June 24th, 2008, 08:00 PM   #30
well i had a common prob.. first of all when i installed my nitrous kit i never changed plugs. the nitrous detonated messed my car up pretty bad it was missfiring like crazy.. went to advanced told the guy i need colder plugs he gave me some 6 dollar each plugs dident help changed the wires dident help.. so took it to a shop they changed my plugs and turns out your not supposed to put those kind of plugs in my car the guy gave me the wrong ones.. so the shop installed ngk plugs and the car runs like a champion.
full exhaust custom H pipe,cai, t-spacer, ud pulleys, 75 wet shot of nitrous, mach 1 rims, Xcal 2 custom tuned nitrous 87 93 octane VMP
9.1@80.07in the 1/8th mile
Old June 24th, 2008, 08:02 PM   #31
Autolite Ignition Spark Plug: Xtreme Performance
Never buy these stupid plugs they suck!! and ther $6.48 a peice.
Old June 24th, 2008, 10:04 PM   #32
i replaced the coil pack and my car is running fine now. Thanks for all the advice.
Old June 24th, 2008, 11:20 PM   #33
Stang Tech's Avatar
this is for superpede1 change the wires or al least test them if you have a new coil and still have a dead cyl. then you either have a bad spark plug wire or faulty wiring to the coil pack it's self. I would go the easy way and check your plug wires don't just change them around change all the wires or test them all. you can also get a spark tester and checked to see if the wires are firing at all. We do this at my shop and it helps us find and fixing misfiring problems
Ford Certified Tech
Ase Certified Tech
1999 3.8 V6
Old June 25th, 2008, 01:52 AM   #34
I finally got my car fixed after another two hours on the phone with my uncle whos a Ford Mechanic. Thanks a lot Stang Tech and everyone else who helped me out, I really appreciate it guys, its nice to know theres helpful people around here.
Old June 25th, 2008, 09:33 PM   #35
Stang Tech's Avatar
wat was the problem. At least it's fixed
Ford Certified Tech
Ase Certified Tech
1999 3.8 V6
Threads Similar to: 2001 Mustang misfiring
2001 Mustang GT OcOnnor220 99-04 18 December 17th, 2007 12:20 AM
2001 mustang 5 speed vs. 2005 mustang auto. DannyStu Drag 20 October 6th, 2007 10:55 AM
2001 mustang v6 vs 1996 mustang v8 Ticket-Me-Yellow V6 Mustangs 13 February 16th, 2007 11:35 AM
5.0 in a 2001 mustang JSmith9136 V6 Mustangs 5 January 20th, 2007 11:00 AM
