Discussing tire size options? in the V6 Mustangs Forum. on a 17 inch rim, i have 245/45/17 in the back, do i ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
01 mustang
tire size options?
![]() LEAVE REP POINTS WHERE NEEDED!!! 2001 mustang V6 CAI,Tuner,Cobra Rims To come: UDP, T-lok, 3.73, full exhaust setup W/flowmaster 40s, aluminum driveshaft. |
how wide are your rims? on an 8 inch rim, the widest i had was 245 up front, 255 in the rear. now on 9 inch rims, i have 255's up front, 275's in the rear. you can fit up to a 275 in the front without rubbing
![]() Submariners Do It Deeper Military Crew MM1 (SS)Bluenose US Navy Veteran |
1999 V6 Mustang
bolt-on auto shootin for a 14.4-14.6
wuts your car bein used for? if drag i would go for the smallest possible which he explained above me and if youre doin autocross or something similar you shoul go wit the widest possible which would be 275
01 mustang
just street performance, im probably just gonna end up putting 245 up front, same in back.
i just wanted to figure out if i could put others up front or not.
'00 3.8L
In my opinion you don't want to go wider than 245 up front (for street driving), which is what I'm running now and on my previous set of rims. The wider the tire the more surface area, the more pull it has, which you don't want to be out of your control. Wide front tires aren't necessary we rock rear wheel drive! Also Wide ass front tires look goofy to me... fat in tha rear!
"Fast she goes...in the City of Overdose" |
01 mustang
what would be shorter up front that would fit on a 17" rim? a 235 or something?
![]() LEAVE REP POINTS WHERE NEEDED!!! 2001 mustang V6 CAI,Tuner,Cobra Rims To come: UDP, T-lok, 3.73, full exhaust setup W/flowmaster 40s, aluminum driveshaft. Last edited by dgt_mustang : June 23rd, 2008 at 01:08 PM. |
#7 | |
1999 V6 Mustang
![]() personally i have 7" wide rims and in front i have 205/65-15 and in back i have 275/50-15 nitto 555r drag radials and i love it
01 mustang
i might go with 235 up front, if i can find one that i can compare it to the 245 and visualy see how much of a differenct it is, for instance i dont want it lookin to awkard with 245 in the back and 235 up front.
the size difference between the 235's and 245's is 10mm...
1986 Mustang GT
^^ yep, less than 1/2 inch.
MILITARY CREW
AT3 |
01 mustang
so it wont even really be noticable unless your throw a tape measure up to it?
'00 3.8L
Exactly, you would be the only person to know unless someone was reading the tires to find the size, or like you said, whipped out the tape measurer.
2k2 Mustang V6
How wide are the rims again?
![]() Selling for friend: Vortech Supercharge kit < 100miles. |
01 mustang
i know they are 17"s but i dont know by what, if you tell me how to measure them i can do it and let you know but all four rims are the same and the back rims have tires on them which measure 245/45/17. if that helps with width.
I Touch Myself Sometimes
91 Sonic Blue Goodness
19.83 @ 12mph
there 17 x8's or 17x8 1/2 wheels. you could run up to a 275 on them
![]() MILITARY CREW FOUNDER SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX widebandsemail joe@tricktuners.com |
Threads Similar to: tire size options?
| Tire Size | 94StAnG5.0 | Visual | 0 | June 1st, 2008 11:59 PM |
| Tire size | Jaevin | 5.0 Mustangs | 6 | June 12th, 2007 10:13 PM |
| stock rim tire options? | 94v6blkndred | Drivetrain | 0 | March 20th, 2007 10:51 AM |
| tire size. | CobraStang161 | 99-04 | 21 | January 8th, 2007 04:54 PM |
| Tire Size | ermister | V6 Mustangs | 1 | October 25th, 2006 12:33 AM |
