Clutch Ticking Sound
Old November 9th, 2006, 09:28 PM   #1
TheTechnical99's Avatar
TheTechnical99 is on a distinguished road
Seems like when I'm driving or just sitting in neutral, I'm hearing a rapid ticking sound from under the hook. Assuming it has something to do with the clutch. It doesn't speed up as rpm's change. If I put any amount of pressure on the clutch, it goes away. I've been told it might be bearings or something but I'm not sure. Anything to worry about? Does it mean my clutch is going?
Old November 9th, 2006, 09:34 PM   #2
chevy_killer's Avatar
2009 v6 Mustang
chevy_killer is on a distinguished road
Send a message via AIM to chevy_killer Send a message via Yahoo to chevy_killer
i have the same problem and my dad thats been working on cars for over 25 yrs said that it is a possible throw out bareing
Old November 9th, 2006, 09:57 PM   #3
CyberPrey is on a distinguished road
I agree with the above 100%... I've had the same issue on other vehicles. Its possible it could be something else, but that is the VERY first place to start looking.
Old November 9th, 2006, 10:05 PM   #4
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
The throwout is usually a good place to start because it takes the most abuse.
Old November 11th, 2006, 08:51 PM   #5
that's what my buddy was telling me - the throw out bearing. since it's not exactly routine maintenance, should I just live with this until I need to replace the clutch?
Old November 11th, 2006, 08:54 PM   #6
2009 v6 Mustang
you could take it to a repair shop and have them replace the throw out bareing
Old November 11th, 2006, 09:30 PM   #7
Originally Posted by TheTechnical99
.....should I just live with this ......
No. If you discover there is a mechanical issue with your vehicle, you really should not live with it.
There is nothing that sucks like having a hot car, but it clicks and clatters....
Also, on a more important note, your car makes noises to tell you that there is something wrong. Living with it simply gives it more time to break, and possibly take other things with it. The longer you put it off, the worse the potential damage is. Now, granted.. there are those cases where living with a bit of noise won't hurt the car (like exhaust heat sheilds rattling...) but then there are cases where it can.
In your case, if your throwout bearing takes a dive off the deep end you could potentially end up without the ability to disengage the clutch. This can make starting and stopping very interesting
Old November 11th, 2006, 10:15 PM   #8
Good point, but I'm just gonna wait until the clutch starts slipping or I need a tow home and just replace the whole clutch. I'll just need to be ready for it when it comes. Car's already got 105K on it. Money isn't exactly running wild around here, nor is free time. I can't spend the time to replace the throw out bearing when I could just be under there for another hour or so and replace the entire clutch.
Old November 11th, 2006, 10:28 PM   #9
lcurle's Avatar
lcurle is on a distinguished road
Send a message via Yahoo to lcurle
It is only the throw out berring, they can take alot. MIne always does it after a hard acceleration or a run down the strip I just set the clutch by pumping it a few times while in neutral, seems to do the trick.
Lee
ATI,CAI, 1 5/8th" Headers, Dynomax dual exhaust(Turn Downs pre-axle), SCT Chip, Cut Springs (2"Front 1 1/2"Rear), FR 9mm wires, Ram Air, 78mm MAH, EGR delete, Rear Sway bar,Sub-Frame Connectors.
Old November 12th, 2006, 06:45 PM   #10
camer is on a distinguished road
Send a message via AIM to camer Send a message via Yahoo to camer
your ticking noise
yeah man it is your throw out bearing. Mine is doing it rate now and my dad just told em what it was and i coundnt figure it out what it was. It is a bitch of a job. do a short throw shifter when you do it and a pressure plate and a fly wheel.
Old November 12th, 2006, 09:33 PM   #11
maybe a short throw if i have the money. I'm used to driving a truck so the stock shifter much shorter than I'm used to. unless someone can convince me it's worth it
Silver 2000 GT: 5 speed/B&M short shifter -- MAC O/R H-pipe and Borla catback -- 17" Bullitts -- spoiler delete -- stubby antenna
Green 1993 Bronco 5.0 XLT
Red 1991 Bronco 5.0 EB Gone
Black 1999 V6 Gone
Old November 12th, 2006, 10:42 PM   #12
turp's Avatar
3 feet...
With a throwout unless it siezes completely you are really better off just replacing it when you get a new clutch. There is no reason to pull the tranny just for a throwout.
Threads Similar to: Clutch Ticking Sound
TICKING??? 04gt 99-04 20 April 19th, 2010 02:46 AM
00 gt ticking smokinv6 99-04 27 April 19th, 2010 02:35 AM
Clutch still has a grinding sound? adam585 96-98 7 November 8th, 2007 01:22 PM
Ticking? mustang kid 1989 V6 Mustangs 14 November 11th, 2006 09:03 PM
Hurray Ticking Sound! Miyvka V6 Mustangs 12 November 5th, 2006 01:43 AM
