the pcm - Forums at Modded Mustangs
post #1 of 14 Old June 23rd, 2008, 02:52 PM Thread Starter
the pcm
well my car threw the code p 0602 which says to replace the pcm(computer) so i called up a junkyard and they said i could get one for 120 bucks....would i need to take it to ford to program it or anything?? thanks
krispy is offline
post #2 of 14 Old June 23rd, 2008, 04:34 PM
04mustang232's Avatar
Send a message via AIM to 04mustang232
ur 2000 mustang needs a new computer already? jeeze, i would do some more investigating but maybe you just got a bad one. But, as long as its from the same body style, i.e. 99-04, same drivetrain (auto or 5speed) and same engine (3.8 or 3.9), i dont think you will need any programming.
Originally Posted by JBIGBOOTSY View Post
I am currently taking a pro dump as we speak. It also feels like about 3" diameter.
04mustang232 is offline
post #3 of 14 Old June 23rd, 2008, 06:10 PM
The soul stealing Ginger
dgt_mustang's Avatar
Send a message via Skype™ to dgt_mustang
if its for your year and your car, you should be fine, idk about that whole wide span of 94-04 cause some of those had options through the computer that yours might not have.
Dr.Gonzo! is the Ultimate IT master, the king of tech, The Dong.
The Dong^?? ZIP!!!
dgt_mustang is offline
post #4 of 14 Old June 23rd, 2008, 07:15 PM
MM's Resident Ricer
GreenFaleen's Avatar
uhh unless you had a nasty short that might have fried it, or you were in a wreck I would check and make sure everything is plugged in correctly also take off your neg battery cable for 15 mins let the code reset and test it again
NCMM #9
GreenFaleen is offline
post #5 of 14 Old June 23rd, 2008, 08:24 PM
Assassin_Dan's Avatar
Send a message via MSN to Assassin_Dan
Wont the PATS system be all screwed up if he replaces the computer?
CAI, Screamin' Demon Coil, Livewires, Steeda Tri-ax, Steeda Clutch Quadrant and Adjuster, UDP, 8.8 rear end with 3.73's, 1/2 inch VAP intake spacer, SCT X3.
Assassin_Dan is offline
post #6 of 14 Old June 23rd, 2008, 09:18 PM Thread Starter
alright ill retry its weird as hell this code didnt show up when i posted i had lean codes and then i looked in recon with sniper and it showed a few codes and this being one ill try disconnecting and reply
krispy is offline
post #7 of 14 Old June 23rd, 2008, 10:21 PM Thread Starter
k tried disconnecting bat....a no go...i changed the tune back to stock no go...the code still popping up so i guess it needs replacing
krispy is offline
post #8 of 14 Old June 24th, 2008, 11:51 AM
Damn that sucks, didnt jump anyone elses car off with your car did you?
The Dong^?? ZIP!!!
post #9 of 14 Old June 24th, 2008, 03:01 PM Thread Starter
nope i didnt im just as stumped as everyone else to why it failed
krispy is offline
post #10 of 14 Old June 24th, 2008, 03:54 PM
walk under any ladders? beat up any kittens? maybe burn down some dog houses or something?
The Dong^?? ZIP!!!
post #11 of 14 Old June 24th, 2008, 06:30 PM
MM's Resident Ricer
that code is comming up cause you have a reflash on the computer. reset to stock drive for 75 miles then let autozone check it that will give you the code thats causeing the CEL if your PCM needed replacing youd have a lot more trouble than a CEL
NCMM #9
post #12 of 14 Old June 24th, 2008, 06:45 PM
i never thought of that......how he would obviously have more problems than just a light if the computer that controls the car is bat......huh. +1 rep for that one.
The Dong^?? ZIP!!!
post #13 of 14 Old June 24th, 2008, 11:34 PM
Stang Tech's Avatar
Send a message via AIM to Stang Tech
i would recommend to do wat GreenFaleen recommend and then unplug your negitive battery cable and leave it off for 20 min. then drive the vehicle for some miles and then have the pcm checked for codes. last option is what is called a HARD RESET you uplug the postive with the neg cable still on the battery and touch the postive cable to the neg cable making sure it is not touching the postive post of the battery. This is some thing we do at work to fix PCM and TCM problems.
Ford Certified Tech Land Rover Certified Tech
Ase Certified Tech Honda/ Acura Certified Tech
AllData Automotive Information Specialist
03 Mustang GT
Vortech V3 Intercooled
407/415 to the wheels
BOOOOSSSTTTTTT
Stang Tech is offline
post #14 of 14 Old June 28th, 2008, 07:04 PM
MM's Resident Ricer
hey man you ever get it figured out?
NCMM #9
Human Verification
