2003 v6
![]() iTrader: 2 reviews
Tires
So my front 2 tires are pretty much bald... and I need to get another set... would it be a bad idea to get a seperate brand of tires for the front? If you guys dont think its a bad idea, could you recomend some good ones that will last me a while? It snows alot here in the winter and i use my car as a DD.
btw i have an 03 sixer |
1995 Mustang convertible
If you don't mind that the tires don't look the same, then there is no reason why you can't have different tires on the front than on the back. In fact, my rear tires are an inch wider than my front tires. Most on here are looking for good performance out of their tires. Unfortunately, as a general rule the better the performance, the shorter the tire's lifespan. I'd say check out tirerack.com to see what they have as far as all weather tires. You could also go to a local tire shop and ask for recommendations. Hope this helps.
MWWarlord 1995 Mustang convertible check out my garage for pics and a complete list of mods. http://www.tricktuners.com |
2003 v6
that helps alot thanks! also i woulnt mind getting my car lowered is there a spring kit i can get that lowers my car without having to buy ccplates? Basically i'll only have the money for springs... (after i buy my tires)
2003 v6
If i get these springs would i "need" anything else? Eibach Pro-Kit Springs (79-04 V6/4 Cyl. Coupe) at AmericanMuscle.com - Free Shipping!
#5 | |
MM's Database Error
![]() I'm trying to get rid of this stuff, feel free to make me an offer!: SCT Mass Air Flow Sensor $200 Tial Wastegate Springs $40 (10psi and 3.6psi) |
Threads Similar to: Tires
| TIRES | vnmous | General Tech | 12 | August 15th, 2007 12:31 AM |
| tires for 07 gt | tweavtheboss | 2005 - 2010 | 6 | August 9th, 2007 06:50 PM |
| Nankang Tires? Republic tires? | Mr.Chips | V6 Mustangs | 1 | January 19th, 2007 05:33 PM |
| tires | terribleonexx88 | 5.0 Mustangs | 4 | December 18th, 2006 08:54 PM |
