1995 Mustang convertible
HELP Transmission Pan Gasket Leaking!
Hey guys, while I know a fair amount about mustangs, I've always been pretty weak when it comes to transmission stuff. I just found out that my transmission pan gasket is leaking. How serious is this? What will it take to fix it? How much should I expect to pay if I take it to a shop? Any help would be greatly appreciated thanks.
MWWarlord 1995 Mustang convertible check out my garage for pics and a complete list of mods. http://www.tricktuners.com |
99 Cherokee sport/87 5.0
not tested
Not too hard to fix, and while you're at it, go ahead and flush out your tranny fluid.
You can buy the pan gasket at autozone, and it'll even come with a new filter. I can give you the same step-by-step I was given. disconnect the lines running from the radiator to the tranny from the radiator. should be two metal hoses that connect to the bottom part of the radiator on the driver's side. Remove the drain plug from the tranny's pan, and drain the fluid. make sure you have a bucket under both of the loose ends of the metal hoses. turn the engine on. turn it off AS SOON AS the hose that spits out the fluid stops spitting it out. take off the tranny's pan, replace the filter, put the gasket on, and bolt it back up. reconnect the coolant lines to the radiator. fill your tranny fluid back up. start the engine, and check the transmission fluid. I didn't do it on my car, I had a shop do it. But that's how I was told how to do it.
[CENTER]"Not the victory but the action; Not the goal but the game; In the deed the glory," -Hartley Burr Alexander |
How much did the shop charge you?
not tested
What you want is a total tranny flush. costs $130. that includes a new gasket and filter.
If you have a drain plug in the torque converter (which I believe you do) you can change almost all the fluid by removing that plug to drain the torque converter and removing the oil pan. Replace the pan gasket and drain plug and refill it. It takes something like 10 qts of fluid. You can add about half of it then run the engine a bit to refill the torque converter and refill again. I would use Ford ATF and a Ford pan gasket. The fluid will be ~$50.
The soul stealing Ginger
dont forget what people say about flushing the tranny, whatever is in there acts like glue for it, if you get a total flush you could be looking at a hell of alot more problems coming up after.
not tested
plug for torque converter is covered by a circular rubber thingy, just so you know.
02vert
this is true if it has not been changed for a long period of time you might regret a total flush just change filter and gasket if that is the case but it's your choice.
+1...cause if theres mounds of debry in your pan and you flush all your doing it flushing all that crud through your entire system..
![]() 94v6.CAI,Exhaust,3:73s-needs rear end rebuild 02GT/Saleen.built motor,62mm turbo 412hp/446tq @10psi,stock TB and intake |
not tested
so um.. take the pan off first.
Post rep for people guys!!! see the the middle icon on the left!!
basically taking the pan off and draining from there, just dont take all the bolts off the pan, loosen them all a tiny bit, use a screw driver to pry the pan and loosen it, it will be all gravy from there....a nasty....kinda foul smelling..gravy. |
#12 | |
![]() 2004 GT Boosted by Vortech |
not tested
lol. I never get rep. give it all the time though..
but yeah. you can do this yourself.
Yeah I actually got a total flush about 6 months ago. I figure that's why I have the leak. I'm not sure what I should do. Should I have the whole thing flushed again, or should I just replace the gasket and filter. BTW el33tist you got rep.
if they replaced the filter and all before, just replace the gasket. or if it comes with the filter, then might as well replace it since it's already down... *shrugs*
Thanks I guess I'll try just replacing the gasket and filter and see if that fixes the problem.
not tested
You're gonna lose most of your fluid when you change the filter. you have to drop the pan to change the filter, so make sure you have more to put in. I wouldn't bother w/ a total flush since you just got one, but go ahead and let the pan drain, change the filter, replace the gasket and pan, and replace fluid. also, check your rear main seal.
Thanks man. I'll give it a try in a week or so when I have a spare second.
Threads Similar to: HELP Transmission Pan Gasket Leaking!
| Floor Pan | dwmb25 | Classic Mustangs | 4 | February 17th, 2008 10:02 AM |
| Oil Pan Gasket Change | poisonstallion95gt | 94-95 | 9 | November 9th, 2007 03:55 AM |
| oil pan gasket? | lugthug713 | 94-95 | 9 | July 11th, 2007 02:32 PM |
| Help! (Oil Pan Gasket) | manny2500 | 5.0 Mustangs | 4 | November 6th, 2006 02:38 PM |
| Transmission Leaking | BraggStang | 99-04 | 5 | July 2nd, 2006 08:02 PM |
