SSStang's V6 Mod Write up.
LinkBack (1) Thread Tools
Old July 9th, 2008, 04:24 AM   1 links from elsewhere to this Post. Click to view. #1
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to allESG-642T is a name known to all
SSSTANG's 3.8L Modifications.
The one that is sticked was copied and pasted and missed a few of my updates, and corrections.
Just put this together to try and help guys asking questions. If I've missed anything or you feel anything is
inaccurately just let me know. Also if you have any questions you can reach me on AIM: LoudMustang2005
1st tier
Basic bolt ons
Headers
- BBK Shorties
- Mac Long Tubes
- Pacesetter
Thoughts: The BBK shorties will do almost nothing for you as the stock mainfolds flow very well. If your going
for headers the Mac Long Tubes seem to be the best thing as of now. Currently MAC is the only producer of
94-04 Long tube headers, however Pacesetter should also be releasing a set of long tube headers for the 94-04
v6 mustang so be on the look out.
7/9/08
The Pacesetter long tube headers have been released.
Cold Air intake
- Short Ram
- Fender well
- "ram air" types
Thoughts: The basic "bomz" eBay cold air intake will work fine. If your car is a show car, or you just like to have
a brand name then you have several options. Their are also the mach 1 "ram air" style intakes. The fender well is
what I would reccomend. The short ram seems to draw hotter air from the engine bay unless its 100% sealed off and
the ram air types are normally expensive and provide the same gains.
Exhaust
- Mid Pipe
- Catback
Thoughts: Great beginner modification. A mid pipe is not needed for an even fire v6 mustang divorced duals may be
ran if you desire. Divorced Duals, tend to have a louder sound. Xpipe, tends to be more raspy. H pipe tends to be
deeper. This can vary depending on muffler choice. You can also have an exhaust shop custom fabricate a catback,
the only difference is you won't get mandrel bends. If your just looking for a small bit more sound a Y pipe catback is
ok, however this is not the best for performance and sound.
Under Drive Pulleys (UDP)
Thoughts: Another great mod. These help buy "under driving" your accessories, causing them to spin slower which frees up power.
If you have a big audio system make sure you get an Over Drive pulley for the alternator. If your Audio system is huge
then you might want to look past this mod.
2nd Tier
weekend projects
Gears
- 3.73
- 4.10
Thoughts: I only included 3.73 and 4.10s but their are other options. 3.73 and 4.10 seem to be the most popular.
Gears will help your car accelerate faster, you won't gain any power but your car will move faster. Steeper gears
(higher number) will get you the fastest acceleration. Their are exceptions to this, when your car is turbocharged
or supercharged you have to consider the best gear for your powerband. (please do not attempt this unless you are
absolutely sure you know what your doing)
T-Lok
(posi,Lsd)
- Ford Racing
- Detroit TruTrac
- Auburn
Thoughts: A tlok will increase your traction buy providing power to both wheels. the 94-04 Mustangs came with an open
differential (you spin your passenger side tire ony). The Ford Racing Tlok seems to hold up to about 300rwhp however
they have been broken with stock power. If you want something better look into the TrueTrac, Aburn, or an 8.8 rear.
(please do not attempt this unless you absolutely know what your doing)
Upper Intake Spacer
- VAP
Where to find: VAP Auto - Intake Spacers, J-Mod Kits & more!
Thoughts: The VAP Intake Spacer will increase the length the air has to travel thus creating more low end torque
and hp. It has been dyno tested to give about 5hp and 7tq. Don't be scared to do this mod yourself the upper intake
manifold may look tough but its fairly easy.
Aluminum Drive Shaft
Thoughts: An Aluminum drive shaft is lighter than stock and will decrease rotational mass and free up horsepower.
Windstar Intake
- 96 through 98
Places to find: VAP Auto - Intake Spacers, J-Mod Kits & more!
CRT RACING PERFORMANCE |
Thoughts: The Windstar intake is a composite intake manifold with longer runners. It is also lighter than the stock
manifold it has been dyno tested to around 7hp and 15tq.
3rd Tier
Into the Engine
All 3rd Tier Mods can be found at the following:
* Super Six Motorsports
* Delk Performance
* Redlined Performance Mustangs
Ported Intakes
- Upper
- Lower
Thoughts: Ported intakes are great modifications. Smoothing casting imperfections, increasing the port entry size,
all allow air to flow into the engine faster. When you can add more air you can add more fuel and get more power.
Ported Head
Thoughts: Ported heads follow the same rules as the intakes to make power. Smoothing the intake side, valve
guides, exhaust side, and bowl work. Here you can also add bigger valves, different rockers, etc.
Camshaft
Thoughts: to make this simple and not confuse anybody a the lobes (egg shapes) on a camshaft make your valves open
and close. A performance camshaft is usually spec'd for your setup and where you want your powerband to be.
4th Tier
Power Adder
SuperCharger Kit
- Procharger: ProCharger Self-contained Superchargers and Intercooled Supercharging Systems
- Vortech Vortech Engineering: Centrifugal Supercharger Manufacturer, Superchargers, Supercharging Systems
- m112
- m90 *94-98 only
Thoughts: Superchargers are a great way to add 80-100+rwhp. The two types available to us are the centrifugal
(vortech/procharger) and the positive displacement m112 thanks to a few creative minds(mysteed/lilroush) and SSMS.
The installs are pretty straight forward. Superchargers are driven buy the accessory belt (or sometimes a secondary
belt) and because of this are less efficient. The centrifugal units will provide boost at around 2.8-3000 rpms. The
Positive displacement unit will provide power from as low as 1.5k rpms. For the 94-98 guys the eaton m90 or thunderbird
s/c swap is an option for you, the m90 has the same characteristics of the positive displacement blower and will give and
instant boost, it's the m112's little brother. You can find detailed information about the m90 swap here: Have questions about the M90 SC? Come here first. - 3.8 Mustang Message Board
Currently to get the M112 "kit" You would need to speak with either LilRoush or Mysteed. They both can be found on
www.3.8mustang.com/forums. If your nice they might put together an entire kit for you.
Updated(7/9/08): Mysteed is now selling the entire kit for 2800$, which only requires fuel mods, tune, and boost gauge.
Turbocharger Kit
- TMA TURBO
Thoughts: Turbochargers are driven buy exhaust gases and are another way to bolt on 100+ horsepower. Unlike the
supercharger you can control boost the waste gate via springs or even an electronic boost controller and set it on the fly. Turbo
installs are normally more complex than superchargers because of more parts. Andy at TMA TURBO has produced
kits that have made 500+ rwhp and taken cars down to low 12 second quarter miles on a stock motor
Tuning software
SCT
Sniper
Diablo
For the most part any car can be tuned with any software. Most of the guys seem to lean toward the sct software. However if the dyno tuner in your area(s) use more of one type than the other It is suggested you get that brand tuner. Sniper comes with the ability to let you "self" tune your car with drop down menus and allows you to tune 2 vehicles. SCT has a PRO RACER PACAGE which is basically what the dyno tuners see (not recommended if you don't now what your doing) and I don't know much about the Diablo software. :WARNING: If you get a device and have no clue what you are doing DO NOT mess with the settings, you could cause catastrophic failure.
Hi, You can call me Kyle
Random ESG fact: Had a prochamber on his v6 before it was popular.
WTB: v6 BBK valve covers
Old July 9th, 2008, 05:02 AM   #2
Safud: MM's Resident Hadji
Safi's Avatar
00 v6 & 99 Cobra
Safi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud ofSafi has much to be proud of
Send a message via AIM to Safi Send a message via MSN to Safi Send a message via Yahoo to Safi
Very nice man...good job
Originally Posted by asiansensation78 View Post
Yeah Safi beat me on OG status lol
Old July 9th, 2008, 05:32 AM   #3
rnorth's Avatar
02vert
rnorth is on a distinguished road
good right up ss
Old July 9th, 2008, 07:09 AM   #4
mannymustang's Avatar
1998 mustang V6
0.2@speed of light
mannymustang is on a distinguished road
will underdrive pullies effect ur a/c at all?
Old July 9th, 2008, 11:17 AM   #5
99v6stang's Avatar
99v6stang is on a distinguished road
very nice write up.
My car ---- (m112 in progress)
Old July 9th, 2008, 12:09 PM   #6
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
the sticky has been updated and more info has been added to. thanks ss
SCT Mass Air Flow Sensor $200
Old July 9th, 2008, 02:48 PM   #7
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
I've never been in a car where it did.
Old July 9th, 2008, 02:50 PM   #8
poindexter18's Avatar
'95 mustang sixer
*Shrugs*
poindexter18 is on a distinguished road
What about split port swap for pre-99 sn95s? Toss that in there even though finding a place to do it is kinda annoying at the moment. =P
-poindexter-
P.S. If its there and I missed it i's sorry, But i have to poop real badly. ^_^
License Plate says it all.
Old July 10th, 2008, 12:31 AM   #9
MWWarlord's Avatar
1995 Mustang convertible
MWWarlord will become famous soon enough
Nice write up. +rep
Damn it..it won't let me rep you
MWWarlord
check out my garage for pics and a complete list of mods.
http://www.tricktuners.com
Old August 2nd, 2008, 04:01 AM   #10
JTS
JTS's Avatar
2000v6/soon 5.0=]
15.45@88.37mph
JTS is on a distinguished road
Send a message via AIM to JTS
nice write up +1
99 svt cobra rims/cai/autolite plugs.
Soon to have a 1990 mustang gt fox
Originally Posted by graystang01 View Post
the smell fuckin exploded out of the box...
Originally Posted by Arsenal View Post
I'm sorry that you haven't evolved past the point of knock knock jokes, but maybe now is the time to learn.
Old August 2nd, 2008, 04:05 AM   #11
Is the game, Ross is the name.
6DXR's Avatar
1998 M3,2K8 Ninja 250
Faster Than Fapsmith's Asian Girl
6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all
Send a message via AIM to 6DXR
Nice work!
I drive a 1998 BMW M3. I used to drive the sexiest Mach 1 in existence. But now I am a 3uroslut
Old August 2nd, 2008, 04:08 AM   #12
JTS
JTS's Avatar
2000v6/soon 5.0=]
15.45@88.37mph
hey SSS how do you like the vortech? i was thinkin about getting it done a while ago but im not sure if i still want to go threw with it? is it worth it?
thanks
Old August 2nd, 2008, 11:38 AM   #13
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
thanks
Oh it'll satisfy 85% of the people on this board...
But I need more!
Old August 2nd, 2008, 01:25 PM   #14
JTS
JTS's Avatar
2000v6/soon 5.0=]
15.45@88.37mph
But I need more!
haha ok i think i might go with it sooner or later
thanks!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/v6-mustangs/79461-ssstangs-v6-mod-write-up.html
» SSStang's V6 Mod Write up. Another Found Self: What The World Is Saying About Another Found Self This thread Pingback July 9th, 2008 07:03 AM
Threads Similar to: SSStang's V6 Mod Write up.
Next mod jbm5781 96-98 34 August 23rd, 2007 10:29 PM
next mod emgjsdk1 V6 Mustangs 22 August 21st, 2007 04:18 PM
mod help? shroom 99-04 54 February 12th, 2007 05:58 PM
mod help...please vaz 99-04 5 February 10th, 2007 12:38 AM
What is the first mod you would do? 04Pony 99-04 21 December 15th, 2006 03:25 AM
