Clutch Or Cable?
Old November 15th, 2006, 02:13 AM   #1
1995 BMW 325i
232stang is on a distinguished road
Send a message via AIM to 232stang
Clutch Or Cable?
well less than 2000 miles ago i put in a ford replacement clutch and today when i was driving i noticed my clutch started to catch much later than it usually does. like it use to catch right when i was letting out now my foots almost all the way up when it catches. the other day i went to the track and went down the track once and then the other time just burned out and then a c6 crashed on the track so i couldnt go down. but do you think maybe my cable needs to be adjusted or that i might have really messed up my clutch. i hope its not the latter because that was alot of work i dont have the time to do again. also if it is the cable(god willing lol) how do i adjust it?
btw when i burned out it was only 5 secs or less just to get the water off my tires since theyre street tires.
Originally Posted by Cesar2cool
lol i use my car for speed
Old November 15th, 2006, 03:27 AM   #2
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
well i doubt you could trash a clutch even if you drove the piss out of it which i doubt is the case. i believe to adjust the clutch pedal your just suppost to pull the pedal towards you and it will readjust. potentially the throwout bearing could be getting stuck. is it always grabbing late or every now and again?
New block with forged internals running 16psi, tuned by Lasota Racing
Too many mods to list...
3.73's and Truetrac Finally Done!
Old November 15th, 2006, 03:33 AM   #3
1995 BMW 325i
always late. well im about to go to walmart so ill pull the pedal up. i doubt it would be the bearing because when i did the clutch change out i changed t/o bearing, pilot bearing, new pressure plate and resurfaced the flywheel. i sure hope the clutch is fine. i dont want to change it on a car im trying to sell.
Old November 15th, 2006, 04:33 AM   #4
1995 BMW 325i
well pulling up on the clutch did nothing. i guess i need to sell it as soon as i can.
Old November 15th, 2006, 07:19 PM   #5
BlackStang is on a distinguished road
Send a message via AIM to BlackStang Send a message via MSN to BlackStang
Burning out wont mess up your clutch right after you put a new one becuse ive done it a couple of times and i have no problems
Im'a Techno Head,Breakbeat Head,Muscle Head... i Got Style So Bite Me ! :]
http://www.myspace.com/hostileact
---Beep---
Old November 15th, 2006, 07:21 PM   #6
1995 BMW 325i
it feels normal now even though its not normal but im used to it. drove 200miles like that so its fine lol. but time to get it out of the driveway and let a 5oh roll up
Old November 16th, 2006, 01:06 AM   #7
¡ʇsnq ɹo uʍop ǝpısdn
Onemanzu's Avatar
... have you guys ever had a ... sticky spot?? on your clutch cable??
like some times my cable will catch a bit then let go ... its hard to explain but thats the best i can do
Old November 16th, 2006, 07:04 PM   #8
2003 Mustang GT
chrish91286 is on a distinguished road
also remembe that the clutch needs to break in first so that might be what your feeling also if yoou do adjust your cable make sure you leeve some free play in the pedal or your clutch will wear very quickly
70mm t/b, plenum, cast intake manifold, full magnaflow exhaust, JLT cai, FRPP c springs, anti roll kit, steeda upper control arms, custom tune, subframe connectors, HID headlights, mach 1 chin spoiler
Old November 16th, 2006, 11:37 PM   #9
1995 BMW 325i
oh ya i broke it in well before i went racing. at least 800 miles before i even raced on it. do i just lift up on the pedal and it does its own thing or what?
Threads Similar to: Clutch Or Cable?
clutch cable..... sivart 5.0 Mustangs 6 September 25th, 2007 04:51 PM
Clutch Cable dStoltenberg 5.0 Mustangs 1 June 19th, 2007 02:17 PM
CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS Hububula 5.0 Mustangs 3 May 28th, 2007 11:08 AM
Getting My Clutch Quadrant, Adjustable Clutch Cable and 97Cobra 4V / SVT 3 May 2nd, 2007 03:33 PM
clutch cable macnesa23 V6 Mustangs 8 March 6th, 2006 01:10 PM
