Ball Joints/Bumpsteer Install
Old July 11th, 2008, 03:24 PM   #1
MM's Official Lucifer
goren813's Avatar
'00 3.8L & '05 4.6L
I have Steeda X2 Balljoints as well as the Steeda Bumpsteer Kit (Hoping this will fix the horrible noises from my front suspension - - if you've seen my other posts). The project seems pretty involved, although I much prefer to do everything on my own. The local (err closest) speedshop FordSpeed Racing in Largo, FL quoted $325 for the install and adjustment.
Just checking to see if this price seems reasonable (I love the shop I've worked with them once before for an alignment after first lowering and they replaced a wheel hub).
Or if anyone has done this and suggests I take a Saturday to attack it myself, and then have the Speedshop just do the final adjustments, which would probably shave a couple hundo off the tab. Any advice is welcome! Thanks.
Old July 11th, 2008, 03:29 PM   #2
Resident Bubblehead
00vabchgt's Avatar
00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough
haven't done the balljoints, but the bumpsteer kit was cake. you change the amount of shims to get the tie rod end parallel with the lower control arm while the suspension has the weight of the car on it...
i can't imagine the ball joints being that hard...
also, make sure that when you thread it onto the tie rod, that you checked how far it's going on versus how far on the original was. they need to be the same, otherwise your car will never drive straight...
Submariners Do It Deeper
Military Crew
MM1 (SS)
Order of the Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
Old July 12th, 2008, 09:37 AM   #3
prodrifterx's Avatar
prodrifterx is on a distinguished road
Send a message via AIM to prodrifterx
balljoints get pressed in and out...probably charging you 4hrs total labor bein 1hr to align, 2 hrs to do ball joints and 1 hr to do the bumpsteer kit. not a bad price imo.
Originally Posted by Fryrice View Post
You cant buy horsepower off a Autozone shelf. If you wanna play you gotta pay.
Old July 13th, 2008, 11:02 PM   #4
goren813's Avatar
'00 3.8L & '05 4.6L
So I went ahead and did the install of the X2 ball joints and Steeda bump steer kit with a friend and we did the complete job in 4 hours. Wasn't bad at all, he had a ball joint press already, and with simple hand tools we did it all. Now all the shop needs to do is an alignment and maybe some slight adjustments to the caster/camber plates and the bumpsteer.
Threads Similar to: Ball Joints/Bumpsteer Install
Changing ball joints 8A_Honda 5.0 Mustangs 24 May 15th, 2010 06:58 AM
Ball joints? dmachine22 99-04 19 May 3rd, 2007 08:07 AM
ball joints winez31 96-98 1 January 7th, 2007 01:35 PM
Ball Joints On Lower Control Arms OTreborO General Tech 0 May 5th, 2006 04:21 PM
