Help, New To Engine Work
Old November 15th, 2006, 10:57 AM   #1
JohnnyMustang is on a distinguished road
I am new to engine work, I have a 1994 3.8l Mustang. I am trying to remove the lower manifold but am having an issue with removing the water return pipe running from the heater hose on the firewall to the water pump. I have removed the retaining bolt at the water pump and the service manual suggest I should be able to pull the pipe out but I am concerned about messing something up. I have also remove the bracket at the firewall end.
Can anyone tell me if this pipe should pull out or is there something else I should do.
John
Old November 15th, 2006, 11:12 AM   #2
the tube is probably stuck. Try twisting it gently while pulling it upward out of the pump. These can be a real pita to get out sometimes and sometimes are rusted so bad, they fall apart when removed and will need to be replaced.
88 Mustang Coupe
www.rickscarcare.net
Old November 15th, 2006, 12:11 PM   #3
Twist 2 Go
Thanks for the advice, just a little concerned about forcing, but you are right it is pretty rusty.
Here goes.
Old November 15th, 2006, 02:50 PM   #4
CyberPrey is on a distinguished road
How did this go for you? I took the top end of my motor off last night, and had a bit of difficulty like this in a couple places myself.
Old November 15th, 2006, 06:44 PM   #5
Worked like a charm, a little extra muscle and some wiggling and out it popped. There is an O-Ring on the internal end at the water pump and it must have been dry.
Thanks again.
John
Threads Similar to: Help, New To Engine Work
Ok what one and will it work Drick 5.0 Mustangs 14 November 6th, 2007 10:16 AM
engine work and emissions 01dutchGT 99-04 7 July 30th, 2007 11:27 AM
1990 GT NO Engine Will 96 4.6 licolin town car engine FIT?? zygo4406 5.0 Mustangs 10 June 4th, 2007 06:53 AM
Will a 2002 Gt Engine Directly Replace a 2000GT engine? Bigb2000GT 99-04 7 April 22nd, 2007 06:09 PM
