Discussing Help, Cant Get Her Restarted in the V6 Mustangs Forum. Ok heres the problem i have a 2000 v6 stang, and it cut off on ...
Old November 16th, 2006, 01:36 AM   #1
Ok heres the problem i have a 2000 v6 stang, and it cut off on me at a red light as i was pressing the throttle, and then wouldnt restart, and hasnts restarted since, i turn the key and it cranks and just feels like its not getting any fuel, so i replaced the fuel filter hoping for an easy fix, but no luck, and yes it has 3/4 of a full tank of gas, it has some basic mods, cold air intake, mac headers, any Suggestions to help me get my pony back on the road again
Old November 16th, 2006, 01:44 AM   #2
MM Phantom
Onemanzu's Avatar
Location: looking for free hand jobs in poland springs nebraska... silly gooses
... is it possible for a fuel pump to seize up??
that would be a guess.... or maybe a fuel line some where has ruptured... any drips or leaks??
Back for brotherly love. My thoughts are with you Bubba!! [9-23-08]
Originally Posted by omz
Old November 16th, 2006, 01:48 AM   #3
hmm
well i did check and there were no visible leaks anywhere on the fuel lines or tank, but to add to the post, before i replaced the fuel filter, the fuel system was depressurized, and i found that .... odd
Old November 16th, 2006, 12:41 PM   #4
SP00LIN V6
2000 Mustang V6
437rwhp 402rwtq V6
maybe you have some shitty oil in it?
computer problems...idk theres a few things that can come in to play here
The Sickest 6
The reason V8 owners on here hate me
Old November 16th, 2006, 01:13 PM   #5
Ninjawafering Puddle Pirate
3.8Coastie's Avatar
1996 Mustang V6
still pushing
there is quite a few things that could go wrong as chris just stated... your best bet to narrow everything down would be to have a diagnostics test run on your car.... if you can try to troubleshoot before you go to a shop by checkin any components that can be easily checked.. you dont want to get into major work and find that it is an easy fix
M90 set up in the works! Thanks to HMUSN!
Originally Posted by HMUSN View Post
I like as much meat as poss on them. that way the rot slower in the shed and can have more" use" out of them
Military Crew
OS2/E-5
Old November 16th, 2006, 04:19 PM   #6
chevy_killer's Avatar
2000 v6 Mustang
well i can give some suggestions such as check the fuel pump (as previously stated) check the gas tank of any trash check the fuel pressure regulator computer (as previously stated) if there was trash check fuel filters again it might not even be fuel related so check the starter altinator battery wires theres a few suggestions
Old November 16th, 2006, 05:22 PM   #7
one quick way to check your fuel pump...
First.. make sure NONE Of your fuses are blown.....
Second... just turn the key to ON... you SHOULD hear your fuel pump do a short bump.....
If none of your fuses are blown, and you do NOT hear the fuel pump do a short bump when you turn the key to on... then check on other things..... This will only verify that the pump IS or IS NOT pumping....
One of the things I would check after the above is that fuel pump relay/shut off switch in the trunk. on my 1997, its in the truck, behind the carpeting where the drivers side tail light bolts are.....
Old November 16th, 2006, 11:42 PM   #8
1995 BMW 325i
same place. behind left taillight
http://img.photobucket.com/albums/v3...5/cpc1copy.jpg
Originally Posted by Cesar2cool
lol i use my car for speed
Old November 17th, 2006, 12:09 AM   #9
ssajdowitz's Avatar
You can also check the electrical system. First, use a spark testor or a good spark plug, but be careful not to shock yourself.
You can check if the injectors are firing by making a cone to help you listen for the clicking of the injectors while someone turns over the motor.
I had the same problem with my 93 Lincoln Continnental (3.8 v6). It suddenly died and would crank but not start. The injectors weren't firing, and I was having a hard time reading codes. It turns out my PCM wasn't getting power due to a bad relay in the CCRM (Constant control relay module). So, I wired in an external relay and all is well.
To the Optimist, the glass is half full.
To the Pessimist, the glass is half empty.
To the Engineer, the glass is twice as big as it needs to be.
Old November 17th, 2006, 10:17 AM   #10
spike627, were you able to check anything yet?
Old November 17th, 2006, 05:42 PM   #11
SP00LIN V6
2000 Mustang V6
437rwhp 402rwtq V6
also battery or alternator...
The Sickest 6
