Engine Swap?
Old November 16th, 2006, 03:13 AM   #1
spike627 is on a distinguished road
Engine Swap?
I am currently trying to decide if i should swap out my 3.8 for a 4.2 and what all would i need to replace and what parts could i keep? im an partially clueless, and should i wait until my 3.8 motor it totally gone... it only has 68k miles on it... because i baby it and only drive it on the weekend or when i wanna show off, but i want more power, and i am definately ordering a procharger intercooler system 11psi but will it fit on the new 4.2? oh so many question someone.. everyone please help
Old November 16th, 2006, 07:04 AM   #2
muneris pro ego
Ninjawafers!'s Avatar
97 5.0 Exploder AWD
snow has nuthin on me
Ninjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to beholdNinjawafers! is a splendid one to behold
Send a message via AIM to Ninjawafers! Send a message via Yahoo to Ninjawafers!
well my stang has well over 100k on it and still runs liek a charm. the 4.2 is just a 3.8 with some work done... you could easily take your engine and rebuild it and make it a 4.2. that is the step that i would be taking.. and getting a new tranny cuz my AODE sucks. if you want forced inductiopn you definitely want some forged internals and a full rotating assembly... which you can get the full forged set with the rotating assembly from super six. and yes the procharger will work on the 4.2.. like i said.. its the same block.. just beefed up
Buy my M90 Kit and my Gears and T-Loc!
MM ZDC - Alaska Base Commander
MM+ Cleavage Club #24
MM Cares Crew / Military Crew
M2C2 President / USCG - OS2
Old November 16th, 2006, 07:50 PM   #3
lcurle's Avatar
lcurle is on a distinguished road
Send a message via Yahoo to lcurle
stock 99+ 3.8L block is aa stout sob. I would wait until your 3.8L is gone before upgrading just to upgrade.
Lee
ATI,CAI, 1 5/8th" Headers, Dynomax dual exhaust(Turn Downs pre-axle), SCT Chip, Cut Springs (2"Front 1 1/2"Rear), FR 9mm wires, Ram Air, 78mm MAH, EGR delete, Rear Sway bar,Sub-Frame Connectors.
Old November 16th, 2006, 07:55 PM   #4
chevy_killer's Avatar
2009 v6 Mustang
chevy_killer is on a distinguished road
Send a message via AIM to chevy_killer Send a message via Yahoo to chevy_killer
if you want power just stroke your 3.8 and get a new top end and get a tt system and do full bolt ons just go to these sites and dont let nobody change your mind
http://www.rpmoutlet.com/newv6m.htm
http://www.tmaturbo.com/
http://www.supersixmotorsports.com/
http://www.americanmuscle.com/
Old November 16th, 2006, 08:06 PM   #5
CyberPrey is on a distinguished road
My personal opinion would be to keep your car basically like it is. You already have the better flowing top end (split port) and your motor should be in fair shape with only that many miles on it.
I probably would NOT recommend an 11psi boost on a stock internal motor though.. you REALLY want to talk to the procharger reps when you order. You are going to need a fuel injector upgrade anyways when you order (unless you stay at 5psi or under...), so talk to them about your motor as well..... AND a tuner.....
AFter you have a few more miles, or when you have the time and energy, or when you just feel that massive URGE to tinker... go with a full 4.3 stroker kit and get the heads ported/polished with big valves..... combine that with your procharger, and thats a pretty mean set up.....
regardless, if your running an automatic, your going to want to invest in a shift kit...
Old November 16th, 2006, 08:13 PM   #6
2009 v6 Mustang
i would personally go with a twin turbo youll get a lot more out of it but a shift kit is only for a auto all it does is it makes the shifts more positive instead of slideing into gear its alot quicker but if you do get one be careful of witch on you get if you get a radical one then you couldnt keep your tires and you may get some tikets because you would be squeeking them all the time
Old November 16th, 2006, 08:15 PM   #7
Actually, the reason I recommended a shift kit was to prolong transmission life... the slower the shift, the more friction is being generated in the clutch packs because of slower engagement.
I agree on chooseing carefully though...
my 1970 gto judge had a full race th400 in it.. even driving as nice as i could, the darn car would chirp the tires on a 1-2 shift That got me into more trouble that when I would run stoplight to stoplight with others....
Old November 16th, 2006, 08:45 PM   #8
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
Re: Engine Swap?
yes it will fit, essentially the "4.2" is only a shortblock, which the added displacement comes from boring the cylinders 0.30 over for a larger piston. ford used this setup in the f150's, some will take the f150 block since it is the right bore size and install a forged rotating assembly to save on machining costs. various shops such as rpm-mustangs, supersix motorsports, moranav6racing and delk offer various shortblocks and longblocks that include just about any combination you want. those shops also offer a variety of stroker kits that go all the way up to 4.6 most will do some sort of head work with the poweradder, there are various options availible from hand ported to cnc'd big valve heads. so there are various ways to approach this but it basically comes down to how much can you spend? there's nothing saying you can't make power with the stock block and heads, justin starkey fabbed up his own twin turbo kit with a few other nessecity mods and ran a high 10.9
you can find most of the websites here
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old November 17th, 2006, 12:22 AM   #9
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
a 4.2 is still the same basic engine..just stroked...mods like s/c's bolt ons, gears, turbo will fit the same as it would on a 3.8
[SIGPIC][/SIGPIC]
Acmillr loves me
Threads Similar to: Engine Swap?
Which one is easier??a rear end swap or engine swap? Bies08 V6 Mustangs 42 May 11th, 2010 05:33 PM
Engine Swap Standardrift V6 Mustangs 13 December 29th, 2007 02:38 PM
Can't decide, engine swap or PI swap? A few questions... k3vin 96-98 24 September 5th, 2007 07:48 PM
Engine Swap help me out jtlogruss08 5.0 Mustangs 15 August 9th, 2007 08:43 AM
Engine swap V6 to V8. HELP Snapsoccer V6 Mustangs 30 May 17th, 2007 09:41 PM
