Another rear end thread
Old July 15th, 2008, 07:14 PM   #1
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
First question is do the 7.5 and the 8.8 use the same t lok. The reason I ask is because it is damn hard to find an 8.8 locally. So im thinkin gears and tlok might have to go on the current rear. Second question is why is the general concensus 300whp on the 7.5 could it poss handle more? Mayb less? should I hold out for an 8.8 or go the cheap route
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old July 15th, 2008, 10:02 PM   #2
Tigerwhite1's Avatar
2003 Mustang V6 Auto
Tigerwhite1 is on a distinguished road
Send a message via AIM to Tigerwhite1 Send a message via MSN to Tigerwhite1
Depends on how much rwhp your planning and if you think it will hold
Most of the time i see that the 7.5 with tlok can handle 300~350ish. Personally I would wait for the 8.8. But it depends on your budget and what your planning for the car.
03 V6 Stang - Auto - Custom gauges (stock at day, red at night )
97 V6 Stang - 04 Drivetrain - Sold for 67
'07 Ninja 650R - Sold for F4i
'95 V6 Stang - 5-speed Vert
67 V8 Stang - Coupe w/ 4bbl 302
'02 Honda CBR600 F4i
'85 Firebird - v6 5spd
Old July 15th, 2008, 10:11 PM   #3
prodrifterx's Avatar
prodrifterx is on a distinguished road
Send a message via AIM to prodrifterx
to answer that no. they have different sizes..hence the 7.5 and 8.8.....same goes for when something says 10 bolt or 12 bolt.....its all based and stated from the differentail/carrier--or tractionlok in this case.---they arent interchangeable. you wont be able to fit an 8.8 tlok in the 7.5 housing...nor would the ring form the 7.5 fit on the 8.8 tlok. vice versa as well one can imagine....personally unless youre positive your gonna pass or hit that mark id stay with your 7.5 if they are hard to find....get 7.5 gears and tlok--from LMR(late model resto) for example.
Originally Posted by Fryrice View Post
You cant buy horsepower off a Autozone shelf. If you wanna play you gotta pay.
Old July 15th, 2008, 10:19 PM   #4
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
ESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of lightESG-642T is a glorious beacon of light
Theirs an m112 guy who was making over 500ft/lbs with his 7.5"
Just throwing this out.
Hi, You can call me Kyle
Old July 15th, 2008, 10:31 PM   #5
hey SSSTang, now that you said that, I remember reading somewhere that its mostly hard launches that break the 7.5, right?
and prodrifterx makes a valid point.
It mostly depends on what your planning on putting into your car I guess.
Old July 15th, 2008, 10:42 PM   #6
hard launches are what destroy anything these days....transmissions are rated to a certain point yet people exceed these all the time some have failures and some dont...all depends on how you treat the car....yet its usually the spline that'll shear first...regardless get a rear end girdle/main cover with support studs/bolts. you will either be budget friendly(this may hurt the wallet down the road) or piece of mind friendly(this one hurts the wallet intially lol)
Old July 15th, 2008, 10:57 PM   #7
[8MINUS2]
ESG-642T's Avatar
2002, Ford, v6
I'm gonna see where the 7.5 goes for me....
>> t/a girdle
>> 28spline moser axles
>> eaton posi
Old July 16th, 2008, 09:42 PM   #8
2000 V6
Id kinda rather hold out for the 8.8 and do it right the first ttime, but my auto doesnt launch hard lol
2000 V6 vert
Old July 17th, 2008, 07:34 PM   #9
2000 V6
Ok so how hard is it to remove a rear if I find one on a car in the u pull it yard? And are all ford 8.8's the same? which ones besides from a stang would bolt right up to my car?
2000 V6 vert
Threads Similar to: Another rear end thread
8.8' Rear end vs. 9" rear end jhooper Classic Mustangs 22 April 25th, 2011 04:59 PM
End All magical pus thread G.T. Rags Pictures 130 July 13th, 2008 09:27 PM
rear pinion nut reverse thread? mustanginca 2005 - 2010 2 July 7th, 2008 10:21 AM
The Thread To End All.... 68 dlxcoupe The Clubhouse 68 June 7th, 2008 02:14 AM
Rear End Help vnmous 99-04 7 February 6th, 2008 03:41 AM
