Auto to manual tranny swap
Old July 20th, 2008, 03:11 PM   #1
2000 V6
ByPopularDemand is on a distinguished road
Send a message via AIM to ByPopularDemand Send a message via MSN to ByPopularDemand
So aside from the Tranny itself what else would I need to do the swap? how hard is it? my auto is about done for(not to mention it has always sucked) and since the car has so many miles no one but ford will touch it...So I decided its 5sp time
2000 V6 vert
Mac LT headers, Mac O/R H-pipe, Mac CAI, ASP 25% underdrive pulley(r.i.p), SCT tune, 8.8 rear and 4.10 gears.
Old July 20th, 2008, 03:18 PM   #2
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
uhh for the price of the swap you could sale your car and use what you would put into the swap for a lower miliage stang
NCMM #9
Old July 20th, 2008, 03:29 PM   #3
2000 V6
But id have to take off my boltons, wait for the car to sale,find a manual then re mod...How much would the swap run you think? This would be me and some buddies that know what they are doing tho and not a shop, so mostly parts
2000 V6 vert
Old July 20th, 2008, 03:31 PM   #4
poindexter18's Avatar
'95 mustang sixer
*Shrugs*
poindexter18 is on a distinguished road
That's a lie Faleen. 2g's max for a rebuilt installed. Or if you wanted to buy like a g-force 2600 or so and you're good to go.
If there's no real shop work you can do it for less than a grand if you get the parts and either repair em or buy a rebuilt tranny.
Tranny 400-790
Bellhousing 45-100
Then a pedal assembly, like 35 from a junkyard
Of course all the linkages and shit, maybe another 60 max
Should probably upgrade the shifter with like a tri-ax or something
Then if you want a new clutch and shit. Then pretty much good to go.
License Plate says it all.
Old July 20th, 2008, 03:37 PM   #5
2000 V6
I could prolly get a tranny from a local forum cheaper than that...So ill need a bell housing and pedal assembly, and linkages? Is that all
2000 V6 vert
Old July 20th, 2008, 04:50 PM   #6
MM's Resident Ricer
2006 Scion tC
13.001@113
Tranny 400-790
Bellhousing 45-100
unless you have a donor car 2.5-4k is what your going to spend easy on parts labor would be about a grand, if he can pull 4 out of his car and puts even 2.5k he could get a 70-80k v6 no problem
but if you have all the parts and the know how your good to go, but your gonna need
Tranny
bell housing
tranny mounts
Master cylinder
Slave cylinder
Hydraulic lines master cyl
Hydraulic lines, slave cyl
Flywheel
Ecm
Clutch
Clutch Pedal Assembley
Shift Linkage
Center console/shiter
ECU
and there are probably a few things im missing
in all honesty something like a lentech street fighter tranny with a higher stall and quick shift system would be a about 1500 if you can install it yourself and a much more economical way to go
NCMM #9
Old July 20th, 2008, 07:05 PM   #7
2000 V6
Ok what if I go the jmod and shift kit route? would I be able to downshift/upshift when I want?
2000 V6 vert
Old July 20th, 2008, 07:16 PM   #8
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
yea, its still not good on the tranny but it will make it stronger with a shift kit.
in most cases...auto to 5speed swap is not worth it
SCT Mass Air Flow Sensor $200
Old July 21st, 2008, 07:31 AM   #9
MM's Resident Ricer
2006 Scion tC
13.001@113
you could but if your tranny is going out i dont recommend it. if you did the lentech swap you could shift when you want as well
NCMM #9
Old July 21st, 2008, 09:28 AM   #10
00 V6 & 09 GT
13.37@104.4mph--BONE stock GT
you'll need a new computer to as well as the tranny harness
clutch pedal assembly
clutch start switch
clutch cable
bellhousing
flywheel
clutch assembly
yoke for the output shaft to the driveshaft
shifter (should come with the tranny)
plus also look at the similar threads seen below
this is asked about as much as exhaust and intake used to be asked
and answered just as much
and the famous its not worth the money just buy a 5speed
[SIGPIC][/SIGPIC]
Acmillr loves me
Old July 21st, 2008, 10:35 AM   #11
mooses is on a distinguished road
It all depends on how much you can get the parts for. I lucked out and got everything cheap and did the install myself. I spent $450 on basically everything needed for the swap and then bought a new clutch kit. If you already have a tuner, you can just get a new tune that will turn off the auto functions in your computer and go without a manual ECU (it's what I did, this is cheaper unless you find a great deal on an ECU). Personally, having done the swap myself, I consider it more important to me than every other mod I've done combined.
Old July 21st, 2008, 11:48 AM   #12
2000 V6
Ah the tuner could prolly help also I was lookin around and a tranny could be had for about 100. What all comes in a clutch kit, and how much did it ren you
2000 V6 vert
Old July 21st, 2008, 12:44 PM   #13
I bought a ram clutch for ~$200 I believe. It comes with a pressure plate, clutch disk, T/O bearing, and clutch alignment tool.
Where can you find a T5 for $100? I'd be careful about where you get it, wouldn't want one that needs a bunch of work.
Threads Similar to: Auto to manual tranny swap
V6 Tranny Swap (Auto to Manual) HELP!! Blue Demon V6 Mustangs 17 July 6th, 2008 01:36 PM
how much does it cost to go from auto to manual tranny? v606er The Clubhouse 13 May 8th, 2008 12:04 AM
V6 auto to manual tranny conversion Curti V6 Mustangs 18 November 6th, 2007 05:54 AM
1997 gt tranny swap - auto to manual lowFidelity 96-98 1 March 20th, 2007 11:32 PM
Auto To Manual Tranny Ninjawafers! V6 Mustangs 6 September 26th, 2006 05:02 PM
