2002 V6 Mustang
I think i might need a new clutch. help anyone??
ok well lets start by saying not many people go into the drivetrain train section,so im gonna post here.
i have a 2002 mustang and when i was driving yesterday my car started to squeal. i put it in first and my clutch was really hard to push down and when i started driving in first it felt like two pieces of metal grinding on one another. then it sort of continued on to second gear then the rest were fine but everytime i did press down on the clutch it would make a nasty squealing sound. my guess is a new clutch the big questions is should I get a stage 1 or 2 clutch?
Ghost Ride The Whip!!!
Throw out bearing would be my guess.
do you make enough power to need a stage2?
#3 | |
2002 V6 Mustang
i dont make enough power yet, i only ask because my guess it would be cheaper to get a stage 2 clutch now then later. but if anyone else has a different opion let me know i could be wrong
MM's Resident Ricer
2006 Scion tC
13.001@113
TO bearing or your friction material is shot
2002 V6 Mustang
so if i can fix my throw out bearing or if my friction material is shot and i fix either one. will my car be running smoothly again???
You should install a complete clutch kit, i.e. disk, pressure plate, t/o bearing, and pilot bushing/bearing. The kit should also have the centralizing tool.
MM's Resident Ricer
2006 Scion tC
13.001@113
if it is just the TO bearing you could just replace that, but might as well get a new clutch of your friction material is gone you need a whole new clutch
Not to be a thread jacker here or anything but last winter I redid my clutch(same problem, throwout bearing went and had a wicked shudder from the previous owner) anyway when the clucth is fully released you can feel the throwout bearing vibrating through the pedal and hear it quite well some times. I know it's back togethor properly and I lifted the pedal to adjust the cable and everything. Anyone have any Ideas???
CAI, Screamin' Demon Coil, Livewires, Steeda Tri-ax, Steeda Clutch Quadrant and Adjuster, UDP, 8.8 rear end with 3.73's, 1/2 inch VAP intake spacer, SCT X3. |
#9 | |
MM's Resident Ricer
2006 Scion tC
13.001@113
Nope it was used and used right, I made sure of it.
2002 V6 Mustang
ok i appreciate everyones input.
![]() so my conclusion will be to get a new clutch. so should i get stage 1 or 2. i am planning on modding my engine so... would a stage two be a better investment than just your run of the mill stock or stage 1 clutch??
MM's Resident Ricer
2006 Scion tC
13.001@113
well at some point it became unaligned
that depends if its not going to see a lot more power its not worth it
The alignment tool is really just an assembly aid to get the disk aligned close enough that the transmission will go back in. The first time you push the clutch pedal in the disk aligns its self.
A more likely cause of your problem is a warped pressure plate so that the release fingers are not all even. That could cause a noise in the t/o bearing when it is pushed up against the pressure plate. |
Stop posting on all these old ass threads!! gtfo!
Threads Similar to: I think i might need a new clutch. help anyone??
| Clutch I need a clutch guru | nHuman | General Tech | 2 | September 22nd, 2009 06:12 PM |
| Clutch Or Clutch Cable OR Shifter??? | 96GtGoodz | 96-98 | 21 | July 27th, 2009 03:59 AM |
| CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS | Hububula | 5.0 Mustangs | 3 | May 28th, 2007 11:08 AM |
| Getting My Clutch Quadrant, Adjustable Clutch Cable and | 97Cobra | 4V / SVT | 3 | May 2nd, 2007 03:33 PM |
| Stage 2 Clutch Kits Or Just Clutch Kits | itschristorres8 | V6 Mustangs | 3 | September 24th, 2006 10:15 PM |
