Air/Fuel Gauge...
Old November 17th, 2006, 05:27 PM   #1
BlackStang is on a distinguished road
Send a message via AIM to BlackStang Send a message via MSN to BlackStang
Air/Fuel Gauge...
Does anyone have a pic for the 02 sensor or te ecu harness to install it ... for a 01 mustang
Im'a Techno Head,Breakbeat Head,Muscle Head... i Got Style So Bite Me ! :]
http://www.myspace.com/hostileact
---Beep---
Old November 17th, 2006, 10:36 PM   #2
lcurle's Avatar
lcurle is on a distinguished road
Send a message via Yahoo to lcurle
ermmm....what do you need that for? You have 4 of them on your car. One after the resignators and one set after the cats
Lee
ATI,CAI, 1 5/8th" Headers, Dynomax dual exhaust(Turn Downs pre-axle), SCT Chip, Cut Springs (2"Front 1 1/2"Rear), FR 9mm wires, Ram Air, 78mm MAH, EGR delete, Rear Sway bar,Sub-Frame Connectors.
Old November 18th, 2006, 01:44 AM   #3
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
This is a wideband right?
If not you are just wasting your time with it...It wont read correctly...They are really just for the looks...
Facebook
Google+
Old November 18th, 2006, 01:35 PM   #4
damn i think its a narrowband .... i got the "autometer" brand
---Beep---
Old November 18th, 2006, 10:22 PM   #5
ssajdowitz's Avatar
ssajdowitz is on a distinguished road
Unless it came with an 02 sensor and a bung to install it in the exhaust, it's a narrowband. Widebands are pretty expensive and don't work off your existing 02 sensors. Narrowbands are accurate only for a short range, hence the name.
To the Optimist, the glass is half full.
To the Pessimist, the glass is half empty.
To the Engineer, the glass is twice as big as it needs to be.
Old November 19th, 2006, 12:52 AM   #6
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
The narrowbands are just a light show...
You could sell it or install it...
I mean it is better then nothing I guess...
Did the gauge not come with instructions?
The gauge is too slow to read off the 02 sensor...
Facebook
Google+
Old November 19th, 2006, 03:07 AM   #7
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
True the narrowbands are mostly just a light show but it is kind of a fun gauge to have anyway if you dont have anything else better to put in its place. their are 2 white wires, 1 grey wire, and 1 black wire off the back of the o2 sensor. the black one is the sending wire you want to tap into.
95 Civic Ex, FnF1's, Morimoto Mini h1 retrofit,
GSR, bbk intake, BDL tb, 57trim t3/t4 8psi, 297whp
96 Civic Ex 2dr, G3 HID retrofit, FnF type 1's, Si cluster, Obd1 Z6 swap
Old November 19th, 2006, 01:00 PM   #8
I see and yeah it only comes with a wire for the 02 sensor
---Beep---
Threads Similar to: Air/Fuel Gauge...
FUEL GAUGE BROKINARROW 5.0 Mustangs 0 November 5th, 2007 05:23 PM
fuel gauge BROKINARROW 5.0 Mustangs 4 October 31st, 2007 09:28 PM
No fuel pressure, Fuel gauge went above full and stayed. woodz72 96-98 6 July 10th, 2007 06:58 PM
air/fuel gauge militarygt 5.0 Mustangs 11 August 2nd, 2006 05:53 PM
air/fuel gauge machy V6 Mustangs 4 July 27th, 2006 12:02 AM
