Ball Joint repair.
Old July 23rd, 2008, 10:30 AM   #1
1989 Mustang Gt 5.0
n/a
sixxxshoooter is on a distinguished road
Send a message via Yahoo to sixxxshoooter
Ball Joint repair.
How much would I be looking at for a Ball Joint repair. I think mine may be going bad. I am hearing some clicking and knocking when I turn the wheel. Mostly when backing out and pulling in. I guess extreme turns. What do you guys think. I researched the part and its only $63. But I know labor usually rapes you and then takes your first born. lol
Old July 23rd, 2008, 11:19 AM   #2
Blown 03 GT
03_StangGuy is a jewel in the rough03_StangGuy is a jewel in the rough03_StangGuy is a jewel in the rough03_StangGuy is a jewel in the rough
Well ball joints arent that hard to replace. It could be a wheel bearing though.
Old July 23rd, 2008, 02:26 PM   #3
MM's Official Lucifer
goren813's Avatar
'00 3.8L
As long as you have a Ball Joint press (auto store will loan you one, it's almost like a spring compressor) It's pretty simple, I just replaced mine recently.
Old July 23rd, 2008, 03:43 PM   #4
1989 Mustang Gt 5.0
n/a
Ok Cool. If its a bearing, what dp you think that would cost?
Old July 23rd, 2008, 04:18 PM   #5
Blown 03 GT
Not sure of the price of the bearing but you can save alot by removin the housing urself and having a shop press it for you. cost me $30 last time i had it dont on my VW.
Old July 24th, 2008, 12:33 AM   #6
1989 Mustang Gt 5.0
n/a
OK. I will look into that. I am going to have a local mechanic take a look at it. I will let you guys know what he says. Thanks
Old July 25th, 2008, 01:02 PM   #7
stephen has a spectacular aura aboutstephen has a spectacular aura about
On later model Mustangs neither the ball joint or front wheel bearing are replaceable by themselves. For the wheel bearing you need a new hub assembly with the bearing and for the lower ball joint it comes as part of a lower control arm. You should check parts availability before you take it apart, so you can estimate the costs.
Old July 25th, 2008, 02:25 PM   #8
goren813's Avatar
'00 3.8L
Later model as in 2005+?? 99-04 comes out of the control arm with a press easily.
Old July 25th, 2008, 03:00 PM   #9
That's useful information. I thought you had to replace the whole control arm.
Old July 25th, 2008, 06:54 PM   #10
1989 Mustang Gt 5.0
n/a
Thanks fellas.
Old July 25th, 2008, 07:09 PM   #11
NinetySixVert's Avatar
1996 Mustang GT Conv.
NinetySixVert is on a distinguished road
Send a message via AIM to NinetySixVert
Just replaced mine too. Wasn't easy at all. I replaced the control arm bushings as well, so when the driver side ball joint actually broke my ball jint press, I took the control arm to Ford and had some guy knock it out for me (free). They were terrible to take out; you would almost think they were part of the control arm on my car anyways haha.
Jack up your car and try to rock/wobble your wheels side to side & up and down. If there is any play in the wheel, it's your ball joint.
Old July 25th, 2008, 07:16 PM   #12
I've never replaced a ball joint myself, but have taken the associated parts out and had a machinist replace them. I have heard that a ball joint press usually isn't strong enough.
Old July 26th, 2008, 03:29 PM   #13
Haha you don't even know. I used one for the passenger side, but when I used it on the driver side the threads on the actual bolt from the press started to compress instead of the ball joint moving at all. Yeah, broke the press, POS rental tools.
Old July 28th, 2008, 11:13 AM   #14
goren813's Avatar
'00 3.8L
That's crazy, my friend actually had a press so I didn't have to rent one. If you take your wheel off you can tell if the Ball Joint is done, if all the rubber bushing is torn up, it won't be able to hold grease, thus the noises occuring from metal on metal. I guess some cars are easier than others, the job wasn't long nor too tedious when I did it.
Old July 28th, 2008, 12:15 PM   #15
ebalderas is on a distinguished road
hey whats up man. if your ball joint are bad that is a fairly easy repair. i just replace mine on my 98 about 4 months ago. the hardest thing to do is taking apart the suspension to where the A arm is free from everything else. You dont need to remove the springs. I only removed the brakes and spindle, and sway bar endlinks to get the A arm to move up and down by hand. Go to autozone and rent their ball joint press and use that to remove and install the new ball joints, make sure you grease them up after you install them if they are the regreaseable type. if you have any question just ask.
Threads Similar to: Ball Joint repair.
lower ball joint theodoor24 Classic Mustangs 5 April 26th, 2008 08:19 PM
lower ball joint 2003_GT General Tech 3 April 9th, 2008 12:03 AM
Ball Joint Time.. Blown5.0 5.0 Mustangs 4 June 4th, 2007 02:37 PM
u joint mustangrebuilder Classic Mustangs 1 March 26th, 2007 09:55 AM
u joint quicksix 5.0 Mustangs 3 January 2nd, 2007 08:55 PM
