fuel pump
Old July 25th, 2008, 04:21 PM   #1
1996 ford mustang
theyanks904 is on a distinguished road
fuel pump
how hard is it to change a fuel pump in a 1996 to a Walbro 255lph pump ? and i was also going to put 42lb injectors .... beacuse of the supercharger
Old July 25th, 2008, 05:45 PM   #2
96gtstang&V6's Avatar
96gtstang&V6 is on a distinguished road
i never done it before but i know you have to drop the gas tank. make sure are low on gas before you do it or else gas will spill out.
2002 mustang v6- Auto, K&N CAI, Flowmaster dual exhaust, Black bullits dd
1996 mustang gt- 5spd, black, cobra hood, stock
November Birthday Club Founder
Old username: 97gt
www.discounttiredirect.com
Old July 25th, 2008, 07:51 PM   #3
Fashion Guru
gooberhead320's Avatar
gooberhead320 has a spectacular aura aboutgooberhead320 has a spectacular aura aboutgooberhead320 has a spectacular aura about
im pretty sure its really easy. for my year you have to drop the fuel tank to install it. im going to install an focus svt pump once my tank hits empty, then putting premium in it and then installing my s/c
Originally Posted by 93hatch View Post
goobers car would whoop on ur fox so you sir fail
im so gay i wish my gf was as pretty as goober
I love 93hatch
Old July 26th, 2008, 12:36 AM   #4
stephen has a spectacular aura aboutstephen has a spectacular aura about
Just be sure the pump is the right kind. The 1996 has a return fuel line while 1999 and later are return less.
I replaced a standard pump on a 99. It's not especially difficult. I would recommend reading the section in the shop manual or a Chilton's manual. There is a grommet in the right side of the fuel tank that the check valve part of the fill tube fits into. It is recommended to cut that grommet apart with a utility knife to aid in getting the fill tube out of the tank. Then a new grommet is needed on installation and they recommend using a surfactant to aid installation. I found a little bit of liquid dishwashing soap worked well.
Once the tank is down and the fuel pump module is out you need to take the module apart and replace the fuel pump part of it. There should be a new tank to pump module gasket which you should install.
Old July 26th, 2008, 09:44 AM   #5
MM's Resident Ricer
GreenFaleen's Avatar
2006 Scion tC
13.001@113
not super hard just annoying
NCMM #9
Old July 26th, 2008, 09:50 AM   #6
HMUSN's Avatar
iTrader: 9 reviews
make sure you have a tune for those injectors on hand.
Threads Similar to: fuel pump
Fuel pump question. Stock GT pump to GT (supercar) pump. Nate's4.6 99-04 15 May 14th, 2008 03:25 PM
Suggestions on Fuel Cell's & Fuel Pump bstang 2.3 Mustangs 5 January 21st, 2008 10:04 AM
Fuel Pump terribleonexx88 5.0 Mustangs 3 December 11th, 2007 05:41 PM
fuel pump perfectspace1 V6 Mustangs 7 October 4th, 2007 06:06 PM
fuel pump fuel pressure stuff JBIGBOOTSY 5.0 Mustangs 2 April 26th, 2007 04:31 PM
